Drivetrain I need you guys opinion.
Old Sep 23, 2014 | 06:25 PM
mikeson's Avatar
mikeson
Hi guys,
I tried to search but couldn't find same.
Anyway, I have 04 Mini cooper S with Cosworth head package.
Car runs smooth but I have this problem developed recently.
When I start car and 1st gear and shift 2nd gear push gas to 2k to 3k then it jump once - just like car misfire once like then it become normal.(like brrrrrrrrrrrrom - bum - brrrrrrrooooooom)
No check engine light nor code.
Just have this once in the morning time and once afternoon when I drive back home.
What do you guys think?
Any input will be welcome.
Thanks in advance
Old Sep 23, 2014 | 06:38 PM
mikeson's Avatar
mikeson
And can I just reset ECU? I mean I have Cosworth head and since I am a second owner, no idea if my car has normal ECU or not.
Worry about if I reset and ECU doesn't adopt my Cosworth head.
and it shows M7 soft wear uploaded.
this is what I found for my package
Stage 1 Cosworth Package:
Cosworth Ported Head
Cosworth Performance Cam
M7 Air Gain System Pro with 62mm Throttle Body
M7 400cc Fuel Injectors
M7 Oil Catch Can
M7 Software Upload
2 Exterior "Power by Cosworth" Badges
1 Cosworth Unique Serial Number & Head Badge
Old Sep 23, 2014 | 07:33 PM
AudioNToxication's Avatar
AudioNToxication
Are you meaning the burble between gears?
You could have RMW retune it.
Theoretically resetting the ecu wouldn't wipe the "tune".
Old Sep 23, 2014 | 07:45 PM
mikeson's Avatar
mikeson
Not between, just 2nd, sometimes 3rd,..between 2k and 3k, it jump.
Like I push gas and RPM raise and all of sudden, it jump once.
So I can reset ECU and it doesn't effect my soft, right?
Cool. Thank you.
Old Sep 23, 2014 | 09:29 PM
AudioNToxication
Maybe bypass valve?
Random is your car blue?
Old Sep 23, 2014 | 10:22 PM
AudioNToxication
Map sensors been replaced?
Old Sep 24, 2014 | 06:37 AM
mikeson's Avatar
mikeson
No and No.
REd mini. =) and haven't replaced anything.
So it is a map sensor or bypass valve?
Again, when I push gas 2k to 3k RPM it smooth raise but one point (just once) misfire like jump. Only once in morning time and once in afternoon.
So I can reset my ECU. Good to know.
jeremy_reyes94
Aug 26, 2015 10:10 AM
Alwyn
Aug 26, 2015 04:53 AM
minipopkart
Aug 13, 2015 05:22 AM
eliseo1981
Aug 6, 2015 05:00 AM
kwijmbo
Aug 5, 2015 09:00 PM
