DSC Light is on but Tyre pressure Indicator Works
Old Sep 22, 2014 | 06:59 AM
dshishman's Avatar
dshishman
Hi folks
I've got 2005 R52 Cooper S. 70K miles on it. DSC Light is on but Tyre pressure sensor not.
Took her to the dealer and they were unable to connect to abs unit. Does anyone have any idea what it might be?
Regards
Davit
Old Sep 27, 2014 | 04:58 AM
mrbean's Avatar
mrbean
If the dealer couldn't connect to the ABS module, then the module is probably dead and needs to be repaired or replaced.
The part is ridiculously expensive. You can try an independent shop that might install a used module or can send the module out for repair to a place like bba-reman.com
Old Sep 27, 2014 | 05:41 AM
dshishman's Avatar
dshishman
I've replaced it twice. Nothing changed. but Just came back from garage... Literally 5 minutes ago finished the work. I found broken Wire. One Wire of DSC/ABS module connector was broken.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Zettinger
Aug 25, 2015 04:04 PM
JamJam43087
Aug 16, 2015 02:02 PM
stellaherself
Aug 14, 2015 05:28 AM
