:: ECS Tuning :: "Hella Horns" | KONI FSDs | ECS Wheel Spacers R60 !
Old Sep 16, 2014 | 02:35 PM
R58/R59 MINI S/JCW GP2 Rear Diffuser
If your MINI is kitted out with the JCW Aero body panels, and you're still searching for a more aggressive look, look no further than the GP2 Rear Diffuser.
A Genuine MINI product, this factory piece installs easily to the JCW Aero rear bumper. Because it's factory, you can expect fit and finish to be on par with the rest of your car.
Accentuate the aggressive bumper lines and brawny center-exit exhaust tips and diffuse any thoughts that you're not driving the baddest MINI around.
*Note* You must purchase, or your car must already be equipped with the JCW Aero rear bumper.
Stylish; Aggressive
Fits:
R58 MINI Coupe S/JCW (2012+) *
R59 MINI Roadster S/JCW (2012+) *
*Only with JCW Aero Rear Bumper
Click HERE for JCW GP2 Diffuser
R53 Koni Shocks & Struts = FSD
KONl shock absorbers with Frequency Selective Damping (FSD) technology, have been specifically designed for the MINI R53, representing the ultimate in comfort and road-holding.
The purely mechanical shocks and struts are independent of electronic control components, making installation easier and product life significantly longer.
KONl FSD suspensions contain an added special valve that controls a parallel oil flow next to the piston, dramatically improving ride quality.
And by retaining the factory ride height, your MINI's wheel fitment & stance will remain unchanged.
Fits:
R53 MINI Cooper S / JCW (3/2002-2006)
Click HERE for the Koni R53 FSDs kit
R60 MINI Countryman ECS Wheel Spacers
Wheel spacers are a great way to get the look you want from your wheels. Set up a more aggressive stance by pushing the wheels out from the body, or as a cure for wheel rubbing if you added a quality lower suspension kit. ECS offers a wide variety of sizes to give you the exact look you need. All spacers are made from a high quality aluminum to keep weight to a minimum and resist corrosion.
Be Aggressive.
Fits:
R60 MINI Countryman / S / SX / JCW (2011+)
Click HERE for ECS Wheel Spacers kits .
R52 MINI Convertible Koni Shocks & Struts = FSD
KONl shock absorbers with Frequency Selective Damping (FSD) technology, have been specifically designed for the MINI R52, representing the ultimate in comfort and road-holding.
Slick Technology
Fits:
R52 MINI Convertible S/JCW (2005-2008)
Click HERE for KONI R52 FSDs kit .
R50/R52/R53 Hood Release Kit
A sticking or broken hood cable is not only a pain when it comes time to service your engine; the issue also presents a significant risk to your driving safety.
Over time, corrosion can cause the release to seize, potentially making it impossible to even open your hood.
ECS now offers the genuine MINI Hood Release Kit, including each part required for the complete job; Bowden cables, left and right side locking latches, and a hood unlocking lever.
The Complete Solution
Fits:
R50 MINI Cooper (6/2002-2006)
R53 MINI Cooper S / JCW (6/2002-2006)
R52 MINI Cooper Convertible / S / JCW (2005-2008)
Click HERE for MINI Hood Release Kits .
MINI Cooper R56-R59 Twin Hella Supertone Horns
Hella Twin Supertone Horns are now available for your MINI.
These horns are characterized by their strong penetrating and concentrated sound, making anyone within a sizable distance aware of your presence.
All of Hella's horns are constructed with durability in mind from impact resistant plastic and feature a 400 Hz low tone and 500 Hz high tone horn.
All kits include the horns, relay, and mounting brackets.
Great for your Custom project: * not play and play.
Be heard
Step it Up
Fits:
R56 MINI Cooper /S/JCW (2007+)
R55 MINI Clubman /S/JCW (2008+)
R57 MINI Cooper Convertible /S/JCW (2009+)
R58 MINI Coupe /S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
Click HERE for the Hella Supertone Horns kit
Jan 4, 2019 12:51 PM
Emnotek
Aug 13, 2015 05:47 PM
Aug 12, 2015 01:24 PM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
