:: ECS Tuning :: Valeo Wipers | Mishimoto Hoses | JCW GP2 Diffuser !!
Old Sep 15, 2014 | 12:29 PM
Valeo R60 / R61 Wiper blade set
Tired of noisy, streaky wiper blades that chatter and don't clean your windshield? Restore your setup with new wiper blades in a minute from Valeo.
This pair of blades is a driver-side and passenger-side pair. The
driver-side & passenger-side pair match your MINI factory size and these
beam style blades contain an integrated wind blade for added aerodynamic
efficiency.
Don't downgrade to a generic brand from the parts store; go Valeo and treat your MINI right!
Swap squeak for sleek
Fits:
R60 MINI Countryman /S/SX/JCW (2011+)
R61 MINI Paceman /S/SX/JCW (2013+)
Click HERE for Valeo Wiper Blades
R52/R53 MINI Cooper S/JCW Mishimoto Aluminum Radiator
Whenever pushing your car past the factory-designated limits of operation, be it through hard driving or performance modifications, adequate engine cooling should always be a high concern.
In fact, improving performance by increasing engine work is only possible when engine temperatures are kept within a reasonable range.
The Mishimoto Performance Radiator is capable of a 30% increase in cooling capacity due to a fully-brazed, two-row aluminum core that's 25% thicker than stock. The direct-fit radiator also uses CNC-machined quick-disconnect fittings for perfect fitment.
Fits:
R53 MINI Cooper S / JCW (2002-2006)
R52 MINI Cooper Convertible S / JCW (2005-2008)
Click HERE for the Mishimoto Radiator
R56 MINI Ziza LED Front Position Lights
Small pleasures make life fun. Take your MINI; small in size, big on looks.
Why not sprinkle a little added flavor over that small pleasure with a set of bright white LEDs for your front position lights.
This is another bright idea from Ziza.
MINI Lights, Maxi Looks
Fits:
R56 MINI Cooper / S / JCW (2007+)
Click HERE for Ziza LED Kits .
MINI Convertible H&R Sport Springs
The most popular spring in H&R's line-up, Sport Springs will lower your MINI an average 1.4" in front and 1.4" in the rear for a lower center of gravity, improved handling, and a more aggressive appearance.
Sport springs are an excellent choice for street and occasional track use, featuring a spring rate that is firmer than the OE Sport spring but still comfortable enough for daily use.
Made In Germany
Fits:
R52 MINI Convertible S/JCW (2005-2008)
Click HERE for MINI H&R Sport Springs .
R55/R56/R57 Mishimoto Radiator Hose Kits
The MINI R55/R56/R57 relies heavily on adequate engine cooling to make reliable power. Any leaking, bending, or warping of the hoses that hold cooling fluid will result in a considerable loss of performance & driveability.
Mishimoto now offers a full Silicone Coolant Hose Kit for the MINI, drastically improving durability over the factory hose arrangement, while eliminating flow restrictions.
Molded to exact OEM specifications, the improved design better withstands heat & pressure, resisting swelling and electro-chemical degradation for a longer service life.
Heat Check
Fits:
R56 MINI Cooper S/JCW (2007-2011)
R55 MINI Clubman S/JCW (2008-2011)
R57 MINI Cooper Convertible S/JCW (2009-2011)
Click HERE for Mishimoto Radiator Hose Kits .
R57 MINI Cooper Convertible S/JCW GP2 Rear Diffuser
If your MINI is kitted out with the JCW Aero body panels, and you're still searching for a more aggressive look, look no further than the GP2 Rear Diffuser.
A Genuine MINI product, this factory piece installs easily to the JCW Aero rear bumper. Because it's factory, you can expect fit and finish to be on par with the rest of your car.
Accentuate the aggressive bumper lines and brawny center-exit exhaust tips and diffuse any thoughts that you're not driving the baddest MINI around.
*Note* You must purchase, or your car must already be equipped with the JCW Aero rear bumper.
Step it Up
Fits:
R57 MINI Cooper Convertible /S/JCW (2009+)
*Only with JCW Aero Rear Bumper
Click HERE for the JCW GP2 Diffuser kit
Jan 4, 2019 12:51 PM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
