Suspension Where to buy top caps for linear KW springs?
Old Sep 14, 2014 | 10:04 AM
2ndof2's Avatar
2ndof2
Changing my STs from progressive rate springs to linear up front.
Need a source to buy top caps for the front that will fit but don't want to get KW's top cap/camber plate combo since I already have Ireland Engineering's fixed camber plates.
The KWs have a 61mm inner diameter.
Not sure about outter diameter or if that spec even matters.
Next step is to find out if Ireland's camber plates can be used with linear top caps once I find some that will work.
Old Sep 28, 2014 | 10:25 AM
2ndof2's Avatar
2ndof2
Allow me to answer my own question:
Ireland Engineering. Had to have the top caps modified by a machine shop for application with 61mm inner diameter of KW's springs but that's the solution. Done.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
W0TM8
Dec 19, 2019 07:50 AM
Emnotek
Aug 13, 2015 05:47 PM
