Drivetrain Help! Promini hub stuck halfway on!
Old Sep 13, 2014 | 08:40 AM
CSC_R53's Avatar
CSC_R53
Hello,
I purchased a used ProMini pulley and went to install on my wife's car today. Well removal of the stuck pulley was easy. I went to slide the hub on and no go. Its a gen1, so needed to be heated. Blasted the hub with a torch and wouldnt go on. Heated some more and gave it a little love tap with a socket and hammer, and now its stuck! Anyone have any ideas on what to do? If I heat the hub on the shaft, the shaft will swell as well. Am I screwed?
Thanks,
Bryan Tracy
Old Sep 13, 2014 | 10:55 AM
Cristhian702's Avatar
Cristhian702
I installed their 17% pulley on my car a while back. From what I recall I just gave it a couple taps with large socket and hammer. It slid right in. I believe it's tapered with a couple of cuts to allow it to open up just enough to slid in. I would tap it in and install the pulley and see if it is aligned properly.
Old Sep 13, 2014 | 04:34 PM
CSC_R53's Avatar
CSC_R53
This one does not have any cuts in it. It is a solid hub.
Old Sep 13, 2014 | 05:40 PM
CSC_R53's Avatar
CSC_R53
Any ideas before I take a cutting wheel to the pulley hub?
Old Sep 13, 2014 | 08:00 PM
00Mini's Avatar
00Mini
If'n it were me I'd call the vendor and see what they have say or a very knowledgable local repair shop if available before I sliced off a new pulley.
Old Sep 14, 2014 | 01:28 PM
Cristhian702
Yeah I would call them and ask. Mine had 3 cuts iirc that ran parallel to the snout of the supercharger that would allow it to open up and compress due to the tapered design. I wish I had pics :(
Old Sep 19, 2014 | 07:52 AM
00Mini's Avatar
00Mini
How did you resolve your problem ??
Old Sep 19, 2014 | 07:54 AM
CSC_R53's Avatar
CSC_R53
Yup.... grabbed my die grinder and cut it off. Bought a WMW 17% pulley and all is good now. Wasted some time and about $100, but all is well that ends well. Plus, my wife was happy that she got to drive my car to work for 3 days.
Old Sep 19, 2014 | 04:17 PM
00Mini's Avatar
00Mini
Good to hear that everything worked out for you.
elverado
Jan 18, 2022 02:51 AM
Doc Pain
Mar 10, 2021 04:50 AM
asmasm
Aug 18, 2016 09:34 PM
MINI Stupor
Oct 1, 2015 11:36 AM
gpwpat
Sep 15, 2015 11:58 AM
