Buzzing/Rattle noise under deceleration
Old Sep 10, 2014 | 10:49 AM
GEMSTER's Avatar
GEMSTER
I have this rattling/buzzing noise coming from the front only under deceleration. The buzzing is not audible under acceleration. There is no noise when revving the car at a standstill. However, the noise can be heard when the car is moving at parking lot speeds (10km/h or less) and revving (clutch in or neutral).
I have gone to the dealer and they said the noise is coming from the HPFP and it is "normal". I havent heard other N18s with this noise.
Can anyone guess what it is? I hope to have it fixed as it is quite annoying.
Here are a couple of clips that captures the noise:
Old Sep 10, 2014 | 11:58 AM
MidnightJCW's Avatar
MidnightJCW
I have the same exact noise coming from the front as well...2013 fJCW btw. It's driven me nuts since the day I got the car but I've more or less learned to live with it as I got tired of taking it to the dealer. The first time they said it was normal until we drove another JCW which didn't make the noise. They ended up holding the car for two weeks and replacing the turbo citing it was a rattling waste-gate but that didn't really solve the issue. Strangely enough after the last oil change it isn't as noticeable as it was prior. I get the feeling its some sort of loose heat shield or exhaust part. I usually notice it most in sport mode while decelerating and the tach drops around 2500 RPM.
Old Sep 10, 2014 | 12:33 PM
GEMSTER's Avatar
GEMSTER
^Mine is loudest in sport mode as well.
I guess I just gotta live with it.
Old Aug 5, 2015 | 10:17 PM
Lantz's Avatar
Lantz
Mine makes the same sh*tty noise. I was really hoping to find a solution on here.
Old Aug 26, 2015 | 01:55 PM
R56BrgMcs's Avatar
R56BrgMcs
mine just started doing this. it doesn't do it when its cold, only does it when warmed up and if I go above 3500 rpm's. It continues to do it until the rpms drop to about 2000 rpm's. Did the dealer tell you its going to cause any issues and needs to be replaced (if it is the hpfp) or fixed if something else? I'm going to remove all the heat shields and re-install them to see if that has any effect after i have it looked at on Wednesday.
Old Aug 29, 2015 | 07:10 PM
GEMSTER's Avatar
GEMSTER
Apparently, the noise is coming from the wastegate flap.They said it was normal.But they did an ECU update to let the wastegate actuator open later. The noise is not as bad now.
Had another GP making the same noise as well. Theres not much you can do.
Old Aug 29, 2015 | 09:32 PM
R56BrgMcs's Avatar
R56BrgMcs
Hmmm, that's unfortunate. My closest dealer is a four hour drive. Looks like I get to enjoy another thing about driving this car. It's weird, I'm constantly on the fence about owning another MINI but I'm also always looking for a first gen park in the garage with it. I've been looking for more of a project car lately and keep ending up looking at MINI's. Anyway, thanks for letting know.
scfiveo
Sep 27, 2019 02:27 PM
unxpectederror
Oct 22, 2015 12:16 PM
Qik420
Oct 4, 2015 08:19 PM
Qik420
Oct 1, 2015 12:02 PM
Miniwaukee
Sep 29, 2015 09:22 AM
