Suspension Hotchkiss Billet Sway Bar Bushing Mounts
Old Sep 7, 2014 | 05:20 AM
Aelwulf's Avatar
Aelwulf
Thoughts on these?
http://www.summitracing.com/search/p...shing-brackets
Looks like both Summit & CarID have them, about $100.00. I like them over the basic thin metal types but not sure the price is worth it. NM's bars come with similar ones, recently updated with the zerks, so I'm also wondering if folks think it'd be a better value over the H-Sport because of it or is it worth the extra to stick with the H-Sport?
NM - $280.00
H-Sport Comp w/ billets extra - $320.00
Old Sep 7, 2014 | 05:34 AM
jkapinos's Avatar
jkapinos
I have the NM 22mm and am very happy with it. Also have the H-sport rear camber links. Don't think you could go wrong with either. Both companies make great products.
Old Sep 7, 2014 | 05:41 AM
danjreed's Avatar
danjreed
Originally Posted by Aelwulf
As a H-sport (25mm) owner - they have "thin" (well, thicker than stock, but just mainly larger) brackets that are just "bigger" versions of the stock design -
Given how close the bar sits to the body/subframe I don't think you would be able to physically fit those larger mounts in place of the stock locations. I'm not sure it would be a possible upgrade - or even worthwhile. Its not like the larger bars are known for stretching or tearing mounts out. My H-sport mounts are pretty much at the limit of what could fit back there.
Old Sep 7, 2014 | 06:03 AM
Aelwulf's Avatar
Aelwulf
Thanks. I've read it's a pretty close fit as-is with the Comps. I didn't know if the area these are in would be impacted, or if there've been reliability issues with the usual ones that could make it worth trying to squeeze in.
Old Sep 7, 2014 | 08:12 AM
countryboyshane's Avatar
countryboyshane
Money burning a hole in your pocket?
The regular stamped brackets the come with the H-sport bars work perfectly fine even in a road race application. They'll find any way to reinvent the wheel to take more of your money
Old Sep 7, 2014 | 01:23 PM
Aelwulf's Avatar
Aelwulf
A bit, but not for these. I've just seen some of the thinner type brackets my dad's taken off cars when I was younger and they were trashed if not broken. No experience yet with them personally so was wondering, especially with two companies now going with the billet as an option.
Old Sep 10, 2014 | 04:08 PM
countryboyshane
They might start to rust out in 15 years, but by that time you'll have a different car.
Mini7
Feb 2, 2016 07:52 PM
Toolman
Jan 20, 2016 06:50 AM
minimofo
Sep 9, 2015 10:29 AM
minipopkart
Aug 13, 2015 05:22 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
