R53 Belt Tensioner replacement tip of the century!
Old Sep 6, 2014 | 05:27 PM
JeanPaul's Avatar
JeanPaul
Hello All,
First off, I've searched all over the web, and this site for instructions on removing and replacing the serpentine belt tensioner, and, as far as I can tell, none of them mention this trick I've discovered.
If you've read any of the DIY instructions on how to remove the belt tensioner all of them state that after the belt is removed, the engine needs to be jacked up in order to slip the tensioner out of the engine bay.
That's the hard way.
Here's the easy way: Remove the dampener first.
That's right, remove the dampener before unbolting the part from the engine. So, instead of removing a rigid part, it becomes a flexible part thanks to the spring in the middle. That will give you enough flex to rotate and move the part toward the front of the car. Then with a couple of slight jiggles, it falls right out. Reassembly is even easier—just don't forget to bolt the dampener back onto the tensioner before motoring.
This tip makes this a 35-45 minute job from start to finish.
Old Sep 7, 2014 | 03:40 AM
Kahnfucious's Avatar
Kahnfucious
Very cool ...I'm subscribing to this as I'll be replacing mine in a few months time.
I'm guessing for reassembly you took the dampener off the new one and slid it into place and bolted it back down?
Old Sep 7, 2014 | 07:53 AM
JeanPaul's Avatar
JeanPaul
Yup, that's right.
Also, upon reflection, if I did it again I'd start the bolts on the tensioner, then bolt on the dampener, then finish tightening the bolts on the tensioner. The dampener helps keep everything in line as it's going up against the engine.
Good luck on your project!
Old Sep 8, 2014 | 02:57 PM
mrbean's Avatar
mrbean
I did mine a couple of years ago and I don't recall having to remove the damper or jack the engine. Maybe it was because I replaced the crank pulley at the same time and likely had it off when the tensioner came out/went in.
Old Sep 9, 2014 | 05:43 AM
JeanPaul's Avatar
JeanPaul
Yes, if you have the pulley out, the tensioner is not obstructed at all. Last time I replaced the tensioner I did it with the pulley at the same time and that made it easy. If you only need to do the tensioner, you're stuck.
BTW, The reason I'm doing this again after only three months is because the Gates tensioner I installed destroyed its rubber dampener bushings. Next time I won't assume that even when parts seem to be of good quality, they aren't necessarily the same quality as OEM.
Old Sep 12, 2014 | 02:33 PM
skucie's Avatar
skucie
Gates makes the OEM dampener. WMW has derlin bushings that will last a lot longer
Old Sep 12, 2014 | 02:39 PM
nkfry's Avatar
nkfry
OEM supplier quality is different from aftermarket quality,even when they are the same supplier, but it's weird you had an issue with the Gates tensioner, as we offer those at near half the cost of the factory one without issue.
Powerflex offers poly bushing inserts that can be replaced in around a half hour, and should offer a lifetime of trouble free operation.
http://www.detroittuned.com/powerfle...amper-bushing/
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Sep 16, 2014 | 08:27 AM
elchilo4ever's Avatar
elchilo4ever
Hi JeanPaul.
So You Say To Remove The Shock First
N' Then The Damper?
Also Ask That Job Is From The Passenger Side
From The Tire?
Old Sep 10, 2018 | 03:02 AM
JKo's Avatar
JKo
I know this is an old thread, but I think it deserves a bump.
I replaced the tensioner on mine yesterday, and this tip certainly helped. I had replaced the belt and s/c pulley on mine just a few weeks ago, before the tensioner started making noises. Didn't want to go through the same engine lifting procedure all over again... so now I managed to swap the tensioner without even taking the belt off. Only thing that needed to come off first was the engine mount bracket, because I was doing the job from above, and not removing the wheel and wheel liner. I did have to support the engine from below though, so lifting it wouldn't have caused much extra work. But I don't think it would have helped that much either.
Old Jun 2, 2019 | 07:55 AM
MERG's Avatar
MERG
Thanks JeanPaul for saving me a ton of grief! Much appreciated! 🤜💥🤛👍🏿👏🏿👏🏿👏🏿🥳🥳🥳🥳🥳🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸 🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸
Old Sep 30, 2019 | 03:43 PM
Apexlate's Avatar
Apexlate
What is the dampener?
By removing the dampener, do you mean the crank pulley?
Old Sep 30, 2019 | 04:35 PM
MERG's Avatar
MERG
NO......he means the thin black shock like piston attached to the belt tensioner.
Old Oct 1, 2019 | 03:39 AM
Apexlate's Avatar
Apexlate
Makes sense now, thanks!
Old Oct 18, 2019 | 04:23 AM
r53-06m6's Avatar
r53-06m6
Yes, thanks for the clarification.
Old Oct 27, 2019 | 12:48 PM
mini-is-for-me's Avatar
mini-is-for-me
Any pictures. This thread would make a lot more sense with one picture. I thought he was talking about the front shock....
Old May 17, 2020 | 04:57 PM
Little peppy's Avatar
Little peppy
Tensioner
Has anyone ever installed a ALTA shock on their R53 pulley tensioner belt? Or is it best to purchase the power flex bushings for my original OEM shock.
Old May 17, 2020 | 07:26 PM
Racingguy04's Avatar
Racingguy04
The general consensus is that they're not a good idea, it's better for the tensioner to be able to move and adjust as it's in use, instead of being fixed like the alta tensioner. I recently replaced my tensioner. The pulley was making noise and the damper wasn't damping at all, but the bushings were actually fine. This tensioner had 17 years and 100,000 miles on it. I put the powerflex bushings in, but in hindsight I'm not sure they're really necessary.
Also I tried the trick on this thread, I couldn't get it to work. I ended up having to put the car into front end service mode to get the tensioner out. If someone finds a way to do it like the OP suggests, I'd love to see a picture or video of it.
Old Jan 18, 2021 | 10:22 PM
Ellie1972's Avatar
Ellie1972
Hi, I use offset ring spanners, wheel off but it's a pain in the bum...
Old Jan 19, 2021 | 05:05 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
that is too much work, I've never found it hard but i remove the spring retainer to make it easier to install it
ikappedkermit
Apr 5, 2015 07:59 AM
KC MCS
Apr 9, 2012 03:47 PM
windman
Jun 11, 2011 07:50 PM
tr6drvr
12
Nov 14, 2008 07:16 PM
ignote
Sep 13, 2007 12:40 PM
