R56 want to switch from 15" to 17" rims on a 08 Mini base
Old Sep 4, 2014 | 11:53 AM
rigsb005's Avatar
rigsb005
Can i upgrade rims from a 15" to 17" with out any problems?
I found a nice set of 17 ruff rims and tires at a good price
Old Sep 4, 2014 | 11:58 AM
3lusive's Avatar
3lusive
As long as they're the same bolt pattern and same or similar offset then it should be fine.
Old Sep 4, 2014 | 03:34 PM
ashchuckton's Avatar
ashchuckton
Sure you can switch, but you are likely to lose performance with a heavy wheel package.
Old Sep 5, 2014 | 07:08 AM
RockAZ's Avatar
RockAZ
You will notice a definite difference in slower acceleration and longer shift points making that switch. Some of that change can be lessened by very careful tire choice to keep the overall diameter as close to the same as the 15" wheels. There are some other reasons besides looks to go with a 17", you can install larger brakes is one important one. 15" wheels can be very light which makes the suspension respond quicker, so check out the relative weights between what you have and the 17" before you buy.
kitty90034
Navigation and Audio
Aug 25, 2015 12:47 PM
MiniSBruce
Aug 12, 2015 10:00 AM
