TSW X Braces back in stock at WMW
Way Motor Works just got a new batch of the famous TSW X Braces for the R55 R56 R57 R58 R59 R60 R61 MINI. If you're wanting to reduce the body flex and make your MINI stiffer the X brace is by far the best solution. Designed years ago by the TSW company, the X design has proven to be the superior. Plus it is the simplest as no drilling or cutting is required to install. The X brace uses 4 existing mounting bolts to make install take less than 5 minutes.
Navigation & Audio My 07 COOPER S has an mp3 jack STOCK!
surfblue
Oct 24, 2018 01:20 AM
