05 wheels on 2011?
Old Aug 28, 2014 | 07:21 AM
Jeffksf's Avatar
Jeffksf
05 wheels on 2011?
Hi new member here. I'm the caretaker of my Sister-in-laws new to her 2011 clubman. I'm currently searching for snow tire/wheel combos and have a lead on a set of 15" steelies off of a 2005 mini. Just wanna make sure they will fit on a 2011 standard Clubman. Any help would be appreciated.
Old Aug 28, 2014 | 09:00 AM
JABowders's Avatar
JABowders
Veteran: Army
I don't know, I do know wheels from a R52, R53 will fit a R56 but the TMPS are different and would need to be changed and/or added so they will work.
Motor on!
Old Aug 28, 2014 | 09:14 AM
Jeffksf's Avatar
Jeffksf
I'm most concerned with bolt pattern (pretty sure those are the same) and hub diameter. Tirerack says 15" diameter will fit so I'm confident in that dimension.
Not concerned with TPMS, we can live with a light on during the winter.
Old Aug 28, 2014 | 09:59 AM
"15" steelies off of a 2005 mini. "
If theye are the standard 15 MINI Steelies. They will fit the Cooper Models ( NON S ) of the R55 Clubman , R56 Hardtop, R57 Convertible , R58 Coupe and R59 Roadser. They will not fit the Coope S or a JCW models( because of those front brakes ). Also if you have a Cooper ( NON S ) Model above with the JCW braking kit ( red caliperis ), they will not fit. .
So if you have a Cooper ( Non S ) you will be fine with those.
TPMS light will be on all the time. So get a tire seal kit and check the tires ever so often.
More info on 15" Factory steelies 36111511414 black or 36116768497 silver . MINI ones even have center caps , that look very nice.
https://www.northamericanmotoring.co...now-tires.html
thanks
Old Aug 28, 2014 | 11:29 AM
Jeffksf's Avatar
Jeffksf
Thanks ECStuning, The seller actually has Mini wheel covers to go with them.
Old Aug 28, 2014 | 01:35 PM
You are welcome, makes the wheels when mounted look more complete. Most people dont know these exist.
Kimolaoha
Dec 5, 2020 09:32 PM
SosoMINI
Nov 22, 2015 03:17 PM
Zettinger
Aug 25, 2015 04:04 PM
HaveATank
Aug 24, 2015 10:26 AM
ludedude
Aug 10, 2015 07:16 PM
