WMW has New Scangauges with Oil Pressure Gauge
Old Aug 19, 2014 | 07:41 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Way Motor Works is excited to have new Scangauge II's with custom MINI programming available. The biggest thing this brings is Oil Pressure readout for 2011+ MINIs with N18 engines and F56 MINIs. Here are the other MINI specific gauges programmed on our Scangauge II:
EOT - Engine Oil Temperature (Degrees Fahrenheit)
OPR - Engine Oil Pressure (PSI)
GAL - Fuel Tank Level (Gallons)
FLT - Fuel Temperature (Degrees Fahrenheit)
PSI - Fuel Rail Pressure (PSI)
FAN - Electric Fan (%)
A/F - Air To Fuel Ratio
TF1 - Transmission Fluid Temperature 1 (Degrees Fahrenheit)
TF2 - Transmission Fluid Temperature 2 (Degrees Fahrenheit)
TIS - Transmission Input Speed (RPM)
TOS - Transmission Output Speed (RPM)
TRQ - Actual Torque (ft-lbs)
TREX
Nov 2, 2019 07:31 PM
Tylerlanger1
Aug 21, 2015 03:03 PM
finn
Aug 21, 2015 07:59 AM
JamJam43087
Aug 16, 2015 02:02 PM
