Rear fog failure indication
Old Aug 15, 2014 | 11:22 AM
cjny's Avatar
cjny
It was a bit of a surprise when the warning indicator for failed rear fog light illuminated last week. I have rear fogs but never use them, so I was pretty sure the bulbs were fine. They are. Both lights work exactly as they are supposed to, but I still get the warning every time I start the car.
It's a 2010 MCS. Does anyone know how to address this?
Old Aug 21, 2014 | 02:57 PM
Michael Cutler's Avatar
Michael Cutler
It could be the bulb/connection for your plate marker, in the rear hatch lift handle.
Old Aug 21, 2014 | 03:02 PM
daddyandmadi's Avatar
daddyandmadi
There is a secret way to see what lamp is out using the stalk button. Check this out
://www.northamericanmotoring.com/forums/r55-clubman-talk-2008/240462-lamp-out-lamp-on.html
Old Aug 22, 2014 | 02:18 PM
cjny's Avatar
cjny
Thanks for the tip on interrogating the OBD.
My problem resolved itself. No more failure indication when the car is started. It's almost as if the act of turning on the fog lights (the first time in years, literally) was sufficient to fix the issue. It couldn't be a some kind of corrosion issue on the bulb contacts that was burned away by the flowing current, could it?
Old Jul 6, 2015 | 04:14 PM
cjny's Avatar
cjny
Follow-up: Shortly after my last post the problem returned. Eventually I pulled the bulbs, cleaned the contacts with a pencil eraser (crude, but effective) lubed them with a little bulb grease and reinstalled. The problem has not returned for months.
Dec 23, 2015 10:36 AM
Aug 19, 2015 12:51 PM
I_drive_slow
Aug 18, 2015 10:47 AM
Powershift
Aug 16, 2015 05:14 PM
