FS:: Perfect Fit 10" Subwoofer Enclosure + 600w RMS Alpine TypeR
Category: Navigation & Audio
Price: $399
++Also includes mounted Alpine SWR-1043D 10" Subwoofer (4Ω + 4Ω) (cost $200 new for the subwoofer alone)
Enclosure Specifications:
-Internal Airspace: .70 -.80 cubic feet
-Mounting Hole Dia: 9.125 inches
-Weight: 13 lbs.
Subwoofer Specifications:
-10" subwoofer with dual 4-ohm voice coils
-Kevlar reinforced pulp cone with Santoprene rubber surround
-cast aluminum frame with perimeter venting and radial finned heat sink
-frequency response: 24-500 Hz
-power handling: 300-600 watts RMS (300 watts per coil)
-peak power: 1,800 watts
-sensitivity: 83 dB
-top-mount depth: 6"
Each Enclosure comes with: High quality terminal cup with the ability to accept up to 8 gauge speaker wire, 2 to 3 feet of 12 gauge Phoenix Gold speaker wire for inside the enclosure, pre-drilled hole for mounting, mounting hardware with instructions, stuffed with polyfill sound dampening for smoother bass response, and comes with Audio Integrations Full Warranty. (see link below for warranty info)
No Drilling Required!! This Perfect Fit Enclosure™ mounts firmly to your Mini with a threaded stud and nut! So no matter how crazy you drive your enclosure won't be going anywhere. Using a factory stud in the storage compartment and our pre-drilled hole in the enclosure it makes for an easy and stealthy install. The mounting hole in the enclosure is standard unless otherwise requested. Please contact us before ordering if your needs differ. Your Enclosure comes standard wrapped in O.E.M. matching carpet.
Feel free to txt or call me at 717-490-0205 with questions.
