R56 P1000 code ?
Old Aug 8, 2014 | 05:26 AM
keithslc's Avatar
keithslc
P1000 code ?
Hello, I am struggling to find info on p1000 code for a 2011 Mini Cooper S. My reader will not reset the code to see if it reappears. Description of code is- WT-system min. stroke adaptation number of stops exceeded
Keith
Old Aug 14, 2014 | 08:52 PM
bluefox280's Avatar
bluefox280
* MINI DTC P1000 (0x2888) - VVT-System Minimum Stroke Adaptation Number of Stops Exceeded
In a nutshell, the ECU is trying to adjust the variable valve timing and cannot meet it's set criteria.
You still under warranty? If so, bring it in and have the dealer determine the reason for the fault.
- Erik
Old Aug 23, 2014 | 05:59 AM
keithslc's Avatar
keithslc
Thanks Erik! Once I figured out that the description was V V T not W T that helped narrow down the system. The code has not returned after clearing. I will follow closely and if it returns leave set to take in to dealer. Warranty is good for another year under the assumption that this is a drive train issue.
Thanks Again!
Keith
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
olson187
Sep 18, 2015 10:26 AM
Mini Hooper
Sep 17, 2015 01:58 PM
Enjoytheride
Sep 17, 2015 12:10 PM
