Codes P0118 and P1638
Old Aug 5, 2014 | 07:53 AM
GingerSnapMini's Avatar
GingerSnapMini
Hello again everyone.
I recently had to change the thermostat housing and sensor in my 2007 MINI Cooper S due to a coolant leak and a code of P0128. While changing this, we also noticed a small coolant leak from the water pump and replaced the water pump and pulley as well. Once the car was put together and the coolant replaced and bled, we started to receive two new codes.
The first worry is a code P1638. We verified and re-verified that all plugs/sensors were reconnected correctly, and are now at a loss as to what is causing this new code. I have been able to clear this code with our scanner tool but it continues to come back each time we restart the car.
The second code we are receiving is P0118. Each time this code is thrown, the fans will kick on as if the car is overheating but the engine is still cold. Once the code is cleared, the fans shut off but within seconds, the code reappears. I checked the coolant temperature on our scanner tool and it is reading 285 degrees even from a cold start.
We have confirmed there is no longer any leaks in the system and the coolant is through the entire system.
Any suggestions?
Old Aug 5, 2014 | 10:44 AM
Slave to Felines's Avatar
Slave to Felines
Sounds like a bad t-stat or one that is not hooked up correctly. Can the plugs go on more than one way? Could you have swapped around a couple of plugs?
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
olson187
Sep 18, 2015 10:26 AM
Mini Hooper
Sep 17, 2015 01:58 PM
Enjoytheride
Sep 17, 2015 12:10 PM
