N14 Oil Leak, Please Help!
Old Aug 2, 2014 | 08:20 PM
michael8238's Avatar
michael8238
Hi all.
My wife's R56 Cooper S has got some oil leak problem. Sometimes there's a small puddle of oil left in our garage from almost the dead center slightly towards the passenger side of the car.
I thought it was the timing chain cover issue, the dealer inspected it and told me the timing chain part was totally fine. SA told me it was just the PCV system leaking oil.
When I jacked up the car, I found the starter motor covered with oil, it seems like the oil is coming from underneath the intake manifold.
I didn't see any significant sign of oil leak on the timing chain tensioner when I replaced it just for the heck of it, and I do see little oil inside the air charge pipe.
Can a cracked PCV hose cause this kind of oil leak? My old Saab had PCV problem and didn't spit out nearly as much oil as this...
Thanks for your help!
Old Aug 3, 2014 | 08:37 PM
minitech88's Avatar
minitech88
I see the vent hose from the valve cover to intake on the left hand side on the back corner leak. The seals on the connections go bad and leak oil at the top or the bottom on the intake side.
Old Aug 3, 2014 | 11:23 PM
michael8238
Thanks man, I'll give it a try since it's cheap & easy to do
woodstudio
Mar 15, 2020 08:28 AM
SheldonCooperS
Aug 25, 2015 11:57 AM
ShadyCoop
Aug 24, 2015 06:05 AM
Lex2008
Aug 16, 2015 08:33 PM
azntaiji
Aug 13, 2015 03:24 PM
