Boring out SSR GT2 for M14 bolts?
Old Jul 20, 2014 | 07:12 PM
bratling's Avatar
bratling
Super Moderator
I have a set of SSR GT2 wheels from my 2006 Mini Cooper S. I'd like to use them on my 2009 Mini Cooper Clubman S. But, MINI went to slightly larger diameter wheel bolts after my old r53 was made, so I cannot mount them.
Is there any reason that I shouldn't have a machinist bore out the bolt holes on the GT2 wheels? Seems like they have plenty of material there.
Anyone have any experience doing this?
Thanks!
Old Jul 20, 2014 | 07:59 PM
ra2fanatic's Avatar
ra2fanatic
Way Motor Works has stud conversion kit so you can mount them without having to redrill. It saves you from red rolling them and diminisioning the value of them.
Old Jul 20, 2014 | 08:08 PM
bratling's Avatar
bratling
Super Moderator
Oh, wow, you are a star! I just hit way's site on your advice and immediately turned up this:
http://www.waymotorworks.com/m14-to-...rsion-kit.html
I'm one of those freaks that prefers bolts to studs, but this is worth a little compromise.
Thanks again!
Old Jul 20, 2014 | 08:53 PM
ra2fanatic's Avatar
ra2fanatic
Yup. Plus it's easier to put wheels on because you can hang them on the studs compared to lining up the holes and then putting one bolt in. Annoying, I don't enjoy those days, especially because I track, so I like to swap wheels.
Don't get the Muteki nuts. They suck.
Get some regular conical nuts here, they're local to me and they're great:
http://europeanautosource.com/produc...m-lug-nut.html
Old Jul 21, 2014 | 02:57 PM
bratling's Avatar
bratling
Super Moderator
Yup. Plus it's easier to put wheels on because you can hang them on the studs compared to lining up the holes and then putting one bolt in. Annoying, I don't enjoy those days, especially because I track, so I like to swap wheels. Don't get the Muteki nuts. They suck. Get some regular conical nuts here, they're local to me and they're great: http://europeanautosource.com/produc...m-lug-nut.html
The nuts from EAS are cheaper too. What's wrong with the Muteki nuts?
Old Jul 21, 2014 | 03:47 PM
ra2fanatic's Avatar
ra2fanatic
The shape of them. Too small. I had a friend run M14 wheels with the Muteki nuts and they always seemed loose. Switched them out to the conical EAS nuts and haven't had a single issue since. Also, having to use the lock extension on every nut when we track is ridiculous.
NYMADMINI
Dec 14, 2016 02:33 PM
Fordgt4
Oct 10, 2015 10:42 AM
buggyeye401
Oct 1, 2015 01:22 PM
buggyeye401
Sep 28, 2015 04:09 PM
EVMini
Sep 28, 2015 10:20 AM
