R56 R56 Aero Kit in Development
Old Jul 7, 2014 | 01:01 PM
SneedSpeed's Avatar
SneedSpeed
Old Jul 7, 2014 | 01:06 PM
Vilas's Avatar
Vilas
Is this for real?
Old Jul 7, 2014 | 01:36 PM
Grizld700's Avatar
Grizld700
And is this an all around kit or primarily a wing?
Old Jul 7, 2014 | 01:46 PM
SneedSpeed's Avatar
SneedSpeed
It will be a full bolt on wing kit and also part of the full aero kit that will include a race front splitter like our R53 one. http://www.sneed4speed.com/mini-r53-...ront-splitter/
Old Jul 8, 2014 | 08:26 AM
v10climber's Avatar
v10climber
Interested in more details on the splitter. The attachment for that wing looks kind of marginal...
Old Jul 23, 2014 | 08:26 PM
Haag75's Avatar
Haag75
I would be very interested to see the full aero kit!
Old Jul 24, 2014 | 11:00 AM
ultrakill's Avatar
ultrakill
That wing looks so stupid. Full-on rice right there.
FWD car with big rear wing is a good way to get laughed at.
Old Jul 24, 2014 | 11:18 AM
Haag75's Avatar
Haag75
That is just it. You don't buy this kit for the looks you get it for the function. If they can find a way to support the down force on with that wing with the brackets this would work great!
I could care less what my car looks like when i'm passing people on the track.
Old Jul 24, 2014 | 11:48 AM
ASuman's Avatar
ASuman
Let me know when you are finished as I would be interested. Need to see the full product thou.
Old Jul 24, 2014 | 01:34 PM
ultrakill's Avatar
ultrakill
Why do you need rear down-force on a FWD car though? I would think more Aero in front is what you really need.
Old Jul 24, 2014 | 02:36 PM
NewCooperFanatic's Avatar
NewCooperFanatic
Reduce lift-off oversteer
Old Jul 24, 2014 | 02:39 PM
SneedSpeed's Avatar
SneedSpeed
You need aero on the front and back to provide equal downforce and best handling. The reason for rear downforce on a FWD is because they can still spin out at speed.
At speed the tires are not going spin on the ground they are going to slide sideways because the car wants to go tangent to the turn. By using air to push down on the front and rear of the car the lateral grip is increased and the car can turn at a higher G force load than without aero. If you only had front down force then the back tires would be lighter, not have as much lateral grip causing the tire slip and the car to spin.
Old Jul 24, 2014 | 03:44 PM
v10climber's Avatar
v10climber
Also with proper front and rear aero you can set the car up loose at lower speeds and the the aero helps stabilize the car at higher speeds
Sent from my DROID RAZR HD using NAMotoring
Old Jul 25, 2014 | 02:25 PM
afadeev's Avatar
afadeev
Unless one does proper down-force measurement and testing, the wing is unlikely to add any down-force greater than the weight of the wing.
Seeing that it looks more like a sushi table and less like a wing, I would love to hear how the folks building it plan to quantify and optimize its benefits?
More on this problem space here:
http://www.f1technical.net/forum/vie...p?p=131958&f=6
a
Old Jul 28, 2014 | 08:25 AM
SneedSpeed's Avatar
SneedSpeed
We haven't tested the MINI with the wing yet but here's a video of our E36 kit in the wind tunnel. They both use the same wing element but the mounting distance behind the rear wheels is different so final downforce numbers at the tires will vary slightly but this will give you an idea.
Old Jul 28, 2014 | 08:33 AM
SneedSpeed's Avatar
SneedSpeed
Old Oct 2, 2014 | 08:31 AM
SneedSpeed's Avatar
SneedSpeed
The Sneed4Speed MINI Cooper wing is done and ready to ship! Fits R53 and R56 hardtops.
http://www.sneed4speed.com/mini-cooper-s-rear-wing/
Old Oct 2, 2014 | 12:55 PM
Indimanic's Avatar
Indimanic
In reading some comments, it's so annoying to see so many nasty meaningless naysayers. Especially when it's fairly obvious those folks appear not to know crap. Now, my comment is at what speed and above is the wing effective and how much?
Old Oct 2, 2014 | 01:03 PM
Grizld700's Avatar
Grizld700
The other question is, this says R56 Aero kit, yet we see the wing on the R53! So does it work with both?
I see there is another thread talking about the R53 wing here:
https://www.northamericanmotoring.co...race-wing.html
Old Oct 2, 2014 | 02:07 PM
SneedSpeed's Avatar
SneedSpeed
The wing works on both cars, R53 and R56.
The wing starts really working above 40mph. Downforce increases as speed increases. We measured the downforce on our BMW E36, which uses the same wing but with different mounts at about 200lbs of downforce at 100mph. The MINI should see slightly higher numbers, around 225lbs at 100mph.
We have a splitter for the R53 http://www.sneed4speed.com/mini-r53-...ront-splitter/ and one for the R56 http://www.sneed4speed.com/mini-r56-...ront-splitter/
Retail price on the wing kit is 899.00 for both the R53 and R56 MINI
ebowling
90
Aug 4, 2019 09:15 AM
Dec 23, 2015 10:36 AM
elightbo
Aug 17, 2015 01:50 PM
Aug 12, 2015 01:24 PM
