R56 NGK Spark Plugs for 2011 R56 with N18 Engine
Old Jul 4, 2014 | 07:49 AM
MINIIZM's Avatar
MINIIZM
I can not seem to find out if the NGK spark plugs from the 2010 R56's (S) will work on my N18 Engine. Has anybody used these?
Old Jul 4, 2014 | 11:29 AM
sgscomps's Avatar
sgscomps
They used the NGK ILZKBR7A-8G on the N14 motor and switched to BERU on the N18 motor since it doesn't look like NGK makes plugs for the N18 motor.
Old Jul 4, 2014 | 12:29 PM
Porthos's Avatar
Porthos
Old Jul 4, 2014 | 04:05 PM
grueinthebox's Avatar
grueinthebox
"This does not fit your 2012 Mini (sic) Cooper S 1.6L L4 Distributorless Turbocharged [blah blah blah]"... Assume a 2011 N18 would say the same...
Old Aug 9, 2014 | 08:24 AM
renchjeep's Avatar
renchjeep
Anyone find the NGK Iridiums for the 2011+ R56 N18 engine yet? I guess the ILKR8E6 were for the earlier engines only?
Old Aug 11, 2014 | 10:06 PM
u238's Avatar
u238
I wouldn't rely on Amazon to make spark plug decisions for me. I use those plugs in my 2011 MCS.
Old Aug 12, 2014 | 08:26 AM
renchjeep's Avatar
renchjeep
u238...How many miles did you put on the stock plugs? How long have the NGK's been in your engine? I assume it is running fine. Any increases in MPG or feel/performance to report?
Thanks in advance.
Old Aug 12, 2014 | 08:36 AM
u238's Avatar
u238
Thanks in advance.
I went about 40,000 on the stock plugs and I've only put about 1,000 on the new ones. There doesn't seem to be any perceptible change in performance. Unfortunately I don't track my MPG so I don't have anything to report there. The NGK's linked are the same heat rating as the Beru plugs that are stock, so imagine that they will perform basically the same.
Old Aug 12, 2014 | 01:31 PM
Systemlord's Avatar
Systemlord
I changed mine at 50k miles and didn't notice any difference anywhere. Remember these plugs use uridium being the second densest element, it will take longer than 50K miles to wear these plugs down.
Old Aug 13, 2014 | 03:16 AM
u238's Avatar
u238
I replaced mine mostly as a precautionary measure. A seized plug that breaks off could really ruin your day.
Old Nov 10, 2017 | 09:56 AM
yrwins acosta's Avatar
yrwins acosta
HI,
im going to replace the spark plug, i need to know what torque pressure i need to used on my wrench. thank you .
Old Nov 10, 2017 | 10:43 AM
bugeye1031's Avatar
bugeye1031
Moderator
My 2009 JCW takes 17 Ft-lbs.
09R56
Nov 16, 2022 10:49 AM
blackie
Jan 18, 2017 09:56 PM
silence2-38554
98
Sep 21, 2016 02:52 PM
yashmack
Aug 15, 2015 10:16 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
