:: ECS Tuning :: Schwaben Wheel Hangers || Ziza LED Kits : CM & R53 || Brake Cables
R56 MINI Cooper Schwaben Wheel Hanger
Our aluminum wheel hanger makes it easy to remove and install wheels. Just thread the hanger stud into a wheel bolt hole and hang the wheel safely while you rotate tires or remove them for service or vehicle repair. It's also great for keeping wheel bolt holes aligned on cars with spacers.
Our improved hanger is made of 6061 aluminum, anodized for hardness and good looks. The knurled, non-slip handle has a drilled hole so you can hang it on a pegboard hook in your garage.
Better still, order two: one for your garage and another for the emergency tool kit in your trunk.
Wheel Convenient
Fits:
R56 MINI Cooper /S/JCW (2007+)
[B]Click HERE for the Schwaben Wheel Hanger
R52 Convertible Parking Brake Cable Kits
Having proper use of your emergency brake in your MINI is a must.
Over time, brake cables can develop rust inside the plastic boot rubber, making the cable susceptible to corrosion and eventually seizure.
If your emergency brake seems to stick and lock your rear brake, or if the parking brake has failed completely, a genuine OEM replacement for both sides is available from ECS tuning.
OEM Assurance
Fits:
R52 MINI Cooper Convertible / S / JCW (2005-2008)
Click HERE for MINI Parking Brake Refresh kit.
R60 MINI Countryman Ziza Interior/License Plate LEDs
Some products need to be experienced to be appreciated.
We can talk about our LED interior lighting kits, but words will fail. We can describe the light as bright and white, crisp and clean. We can even tell you that our complete interior LED kit will banish ugly yellow illumination and showcase the rich features of your dash and interior trim like never before, but it won't do them justice.
Oh well. Guess you'll just have to take advantage of our free shipping on full kits, and see for yourself what a dramatic change LEDs can make to your car, both inside and out.
Ziza; Light Years Ahead
Fits:
R60 MINI Countryman Base (2011+)
R60 MINI Countryman S (2011+)
R60 MINI Countryman SX (ALL4)(2011+)
R60 MINI Countryman JCW (2012+)
Click HERE for R60 MINI Countryman Ziza LED kits or for more information.
R50/R53 MINI Parking Brake Refresh Kits
Replace your snapped or rusted cables.
Fits:
R50 MINI Cooper (2002-2006)
R53 MINI Cooper S / JCW (2002-2006)
Click HERE for Parking Brake Refresh Kits or for more information.
R50/53 MINI LED Interior Lighting Kits
Fits:
R50 MINI Cooper (7/2004-2006)
R53 MINI Cooper S / JCW (7/2004-2006)
Click HERE for Ziza Interior LED Kits or for more information.
R57 MINI Convertible Jack Pad Adapters
Take the danger and aggravation out of lifting your MINI with the ECS Tuning Jack Pad Adapter. Designed to fit the head of a standard floor jack, the adapter has a rectangular head that firmly engages the chassis jack pads.
Positive engagement at jack head and chassis resists jack slippage and shifting, while the raised adapter head prevents damage to rocker panel trim and underbody panels.
Made of black anodized aluminum for added strength and corrosion resistance, the adapter fits the head of most hydraulic floor jacks, including the Schwaben Low Boy
Raise to the Occasion
Fits:
R57 MINI Cooper Convertible /S/JCW (2009+)
Click HERE for ECS MINI Jack Pads or for more information.
Jan 4, 2019 12:51 PM
Aug 11, 2015 11:58 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
