R50/53 Quick reply would be appreciated
Old Jul 2, 2014 | 10:25 AM
madge cooper's Avatar
madge cooper
Hey,
Will Harmon Kardon speakers work in an R50 with an aftermarket amplifier and headunit or do you need to get the full HK setup?
Old Jul 2, 2014 | 01:37 PM
Fly'n Brick's Avatar
Fly'n Brick
Mixing amplifiers and speaker brands is not a problem as long as you match impedance. An 8 ohm amplifier needs an 8 ohm speaker for instance. You will find the common impedances to be 4, 8 and 16 ohms. If you run, say, an 8 ohm output into a 4 ohm load you will over heat and eventually burn out the amplifier.
Old Jul 2, 2014 | 01:41 PM
Fly'n Brick
PS: Every piece of electronic audio equipment has the impedance clearly marked on the box and on the back of the unit. The graphic symbol for ohms is the omega, i.e. Ω
Old Jul 2, 2014 | 03:37 PM
ZippyNH's Avatar
ZippyNH
Quick answer...
No.
Impedance is nonstandard.
Old Jul 2, 2014 | 03:42 PM
bavmotors's Avatar
bavmotors
Y not just use aftermarket speakers also?
Colt45Magnus
Aug 27, 2024 05:03 AM
donniedarko
Oct 21, 2015 01:15 PM
BucksCountyR57
R57 :: Cabrio Talk (2009+)
Sep 21, 2015 05:42 AM
KristaMcCoy
Sep 12, 2015 05:37 PM
OutMotoring
Sep 8, 2015 06:27 AM
