R50/53 changing front axle 2003 mcs
Draining the transmission oil is not a requirement but be prepared to catch a flood of it once you pull one of the half-shafts out. The oil seals around the output of the differential is all that's holding the oil in the tranny.
You may want to change out your oil seals as well since you have the shafts out. Also a good time to replace any or all of the front suspension parts that are likely worn as well.
R50/53 Replacement AC compressor??
PrimePower
Aug 16, 2015 06:29 PM
dyeLucky
Aug 7, 2015 07:10 AM
