R50/53 Whirring sound between shifts?
Hey guys as of late my 2003 MCS has been making a whirring sound in between shifts no other way to describe it than that. Car has 98k miles on it..I'm guessing when the Throw out bearing starts to go the bearings in it can do this?
No sound at idle (clutch in or out).
Hoping this is not an engine bearing or larger transmission issue. Thanks
The "S" doesn't have the infamous Midlands transmission but that doesn't mean you don't have a bearing going out. But there are several places that I'd check:
1) Wheel bearings.
2) Half-shaft CV joints.
3) Output bearings on the differential.
4) Any of the transmission bearings.
I had a "whirring" start suddenly on my 2003 Cooper with Midlands 5-speed. I put the front end up on jacks so both wheels were off the ground and I was able to rotate the wheels and see where the sound was coming from. I ruled out the wheel bearings and CV joints since they were quiet. The sound was in the tranny and so I knew it needed to come out. Turned out to be one of the bearings on the input shaft - the far end one not the one nearest the clutch.
1) Wheel bearings.
So I've actually determined now it's at 3500 rpm in any gear with or without the car in gear...it's more of a resonance I guess but the closest I can describe it is a whirring noise....hmm. Car drives fine -- but this has me wondering.
Any experience with what a idler pulley sounds like when the bearings go? That was one of my other thoughts..
It could be normal. I know I get hyper-sensitive to any noises when I suspect something might be wrong.
Hey 442rick..thanks for reply I'll give this a test out. I've also noticed it only happens when it's hot out ( i run the ac all the time almost). In the AM on the way to work when it's <75 degrees no whirring, on the way home 90+ degrees I get the whir.
Colt45Magnus
Aug 27, 2024 05:03 AM
wildwestrider
Dec 27, 2015 08:20 PM
wildwestrider
Sep 4, 2015 06:25 AM
SneedSpeed
Sep 2, 2015 05:34 AM
