Interior/Exterior T-Connector
Old Jun 21, 2004 | 02:00 PM
jdemaria's Avatar
jdemaria
T-Connector
Hello,
Does anyone know where I can find the T-connector needed to install a boost guage on the MCS.
Thanks.
JD
Old Jun 21, 2004 | 02:03 PM
ZAMIRZ's Avatar
ZAMIRZ
local auto parts store, look under the vacuum lines aisle and there should be all kinds of different sizes.
Old Jun 21, 2004 | 07:47 PM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
Besides the T-fitting, you may also need a short rubbery vaccum tube to connect the T to the tube, fuel pressure regulator, etc...:smile:
Old Jun 21, 2004 | 08:17 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
This is the tee I used for mine. This can be gotten at almost any auto parts store. Being that I tapped into the vacuum circuit at the fuel pressure regulator (the most recommended point), there is not too much room, so I used a 'wye' instead. A short length of vacuum line and an 'adaptor' to connect the nylon boost gauge line is also shown here.
A view of the installed teel with everything connected, looking in from under the intercooler elbow:
Another shot from the side showing the boost gauge line connected:
Hope this helps!
Old Jun 21, 2004 | 09:10 PM
jdemaria's Avatar
jdemaria
Thank you all for the information.
Jarrad
LOKI
Feb 20, 2008 07:07 AM
