R56 Brake Fluid How-To Write Up
Old Jun 21, 2014 | 07:40 PM
kyoo's Avatar
kyoo
Didn't see one immediately off the bat, thought I'd post my how-to. Much, much easier than I thought it would be. Special thanks to ljmattox for the help!! It's a one man job with the power bleeder but I'm grateful that he taught me how to do it.
https://qlmotorsport.com/2014/06/19/...change-how-to/
Old Jun 21, 2014 | 08:04 PM
Eddie07S's Avatar
Eddie07S
Kyoo, Nice write up.
Personally, I would siphon off the old fluid first and fill the reservoir with fresh fluid before attaching the pressure bleeder. This will cut down on the amount of fluid that you need to get clean/fresh fluid through the system. With that said, I have done it both ways. BTW - be really careful with the turkey baster, brake fluid doesn't have the surface tension that water has and the brake fluid will easily run out of the baster as you try to move it to a suitable container. You don't want to get the fluid on anything.
Old Jun 21, 2014 | 09:06 PM
Porthos's Avatar
Porthos
Nice but what did you do about the ABS?
Old Jun 21, 2014 | 09:17 PM
kyoo's Avatar
kyoo
thanks guys. both were addressed at the bottom.
i didn't do anything about the abs, as it was my understanding that it just has some old fluid in it - not a big deal IMO
Old Jun 22, 2014 | 07:24 AM
pokeyjoe's Avatar
pokeyjoe
Veteran: Navy
If you have a clutch, now is the time to flush that line as well. Its right there and really easy.
Plugging a product you sell was a little cheesy, but what I've come to expect from anyone associated with Amsoil.
Old Jun 22, 2014 | 07:59 AM
kyoo's Avatar
kyoo
well two things as far as that goes - 1, like as i try to make explicit - i don't make any money off of it - zilch - i have a normal job, so selling amsoil isnt my lifeblood and i'm not desperate to sell it. it's more of a service for anyone who wants it at no upcharge, compared to many dealers who do.
2, it's right up there as far as the best you can do with brake fluid: http://forums.evolutionm.net/vendor-...ck-review.html
Old Jun 22, 2014 | 12:12 PM
pokeyjoe's Avatar
pokeyjoe
Veteran: Navy
Well, OK, I was hoping to avoid yet another pro-Amsoil discussion, but the referenced thread is not valid for brake fluid comparisons. Go to this link:
Leland West
If you sort by wet and dry boiling temps, you'll find Amsoil near the bottom in both cases. That being said, if Amsoil works for you, use it.
Old Jun 22, 2014 | 12:28 PM
kyoo's Avatar
kyoo
Leland West
i've seen that link - and with that in mind, that's just based on what the manufacturers themselves claim it to be. the referenced link is a well known TTA driver who has set numerous track records for the TTA class. he boiled motul (rated higher on the list), and he didn't boil amsoil. good enough for me, not sure why it's not a valid comparison. sounds more like you have a chip on your shoulder about amsoil, or at least typical amsoil dealers.
i don't care what brake fluid anyone uses and that wasn't the point. i just didn't see a write-up with pics before. and again i don't vend amsoil, i don't make any money, so ultimately it's just a small hassle for me to order it for someone - but if they do want amsoil and don't want to deal with a pushy vendor and markup for something that's already expensive, i can order it for someone with no additional cost - i.e., dealer price. no claims that it's the best.
Old Jun 22, 2014 | 05:14 PM
pokeyjoe's Avatar
pokeyjoe
Veteran: Navy
Still pretty cheesy.
Old Nov 30, 2014 | 10:13 AM
automan21's Avatar
automan21
Any write up on this?^^^^^^^^^
Old Nov 30, 2014 | 01:12 PM
SC R60's Avatar
SC R60
Thanks for the write up. I put solo-bleeder valves on my last car for brake fluid flush. My power bleeder was my daughter. I might invest in a pneumatic power bleeder if I flushed as often as it sounds like you do, or had a local club where we'd do multiple cars.
Old Nov 30, 2014 | 01:57 PM
cristo's Avatar
cristo
Alliance Member
Maybe, ... If you get any air into the clutch circuit (running the resevoir low
or via the bleed outlet) , you may be in for a real treat getting it out.
Old Nov 30, 2014 | 09:12 PM
Zillon's Avatar
Zillon
Nice write up. I need to do a full bleed on the fiancee's Justa soon - need to do a gear oil change first.
Dude, just knock it off already.
Old Jan 1, 2015 | 06:51 PM
automan21's Avatar
automan21
Anyone know where I can get the slave cylinder tool to bleed the clutch? The bleeding of the brakes is easy if you have a helper to pump brakes or a pressure bleeder.
Old Jan 2, 2015 | 06:27 AM
cristo's Avatar
cristo
Alliance Member
Here's where I got one:
http://www.bavauto.com/shop.asp
Showing products for 2003 Mini Cooper.
(Click for a larger image) Use the Bavarian Autosport Clutch Slave Cylinder Bleeder tool to properly bleed the fluid at your BMW's clutch slave cylinder. Most BMW's have the clutch slave cylinder mounted in a position with the bleeder screw pointing downward or to the side. This can allow air to remain in the cylinder during bleeding. The BMW recommended practice is to remove the cylinder from the transmission, affix it in the special, expensive, BMW tool and hold the cylinder with the bleeder pointing upward ...... then bleed using a pressure bleeder. We have encountered this situation on numerous occasions and decided to design and built an affordable tool to perform the BMW prescribed bleeding procedure.
We have also found that later BMW models that have the bleeder screw pointing upward, in the installed position, can benefit from using the clutch slave cylinder bleeder tool. Even these models will bleed faster and more completely.Use the clutch slave cylinder bleeder tool when performing your annual brake fluid flush or whenever the clutch slave or master cylinders are disconnected or replaced.
Part Number Description Price Qty. CBT TOOL [SIZE=6] Tool - Clutch Bleeder [/SIZE]
$ 34.95
Gremothra
Sep 9, 2015 08:42 PM
wildwestrider
Sep 4, 2015 06:25 AM
squawSkiBum
Sep 2, 2015 09:56 PM
Ntety
Sep 2, 2015 08:39 PM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
