Weight of mini cooper factory rim R119
Old Jun 21, 2014 | 08:53 AM
sbninja's Avatar
sbninja
I have searched and haven't found an actual weight of my rims.
These rims are in my 2013 Mini Cooper S coupe. They are the 16"x6.5" with 195/55r16 contiprocontact SSR's.
I believe the rims are the mini factory R119 6star twin spoke rims In silver.
I just removed one the the rear wheels to patch a screw in the tire:( .
So while off I weighed it. Came in at 41lbs on a Berkeley digital scale calibrated with know weights.
The tires, according to tire rack specs weigh 23lbs so the rims would be 18lbs that's with tpms valve assemble and balancing weights.
The weight could be a bit different as the tires have 23000 miles on them.
Here's a pic of the rim if they are not R119 I'm sure someone could chime in.
Attached Thumbnails Weight of mini cooper factory rim R119-image-1647734668.jpg
Old Jun 21, 2014 | 10:05 AM
hsautocrosser's Avatar
hsautocrosser
Same wheel in black mounted with 195/55-16 ContiProContact 87V @ 2500 miles: 41.2 lbs on a scale which rounds to the nearest 2/10ths. Continental's website says the tire weighs 21.5 lbs but it also says the tread depth is 9". MINI2 lists the wheel weight as unknown.
Old Jun 23, 2014 | 04:08 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
see
https://www.northamericanmotoring.co...19-wheels.html
One owner reports a weight of 18.5 lbs per wheel on a bathroom scale, not too bad for an OEM wheel.
phrza81
Oct 10, 2015 11:37 PM
Minii cooper bean
Aug 11, 2015 02:10 PM
nomar116
Aug 9, 2015 09:42 AM
joelcseymour
Aug 7, 2015 12:43 PM
M7Speed
Aug 6, 2015 01:48 PM
