Navigation & Audio large speaker is not work
Old Jun 20, 2014 | 10:23 AM
Sirjojo's Avatar
Sirjojo
Hi guys:
just noticed that my 06 works speaker is not working. how can I test if it's the speaker, or maybe it's the radio setting?
Old Jun 20, 2014 | 10:30 AM
ZippyNH's Avatar
ZippyNH
Huh?!
Please restate your issue...
Which speaker....
Which sound system/radio...etc.
Old Jun 20, 2014 | 11:34 AM
Sirjojo's Avatar
Sirjojo
the big speaker on the front doors has no sound. I only get sounds from the little speakers by the door handles
I have a 06 cooper works
Old Jun 20, 2014 | 11:41 AM
Its could be the connection at the terminals or the speaker is dead. This speaker is located at the bottom of the front door ( woofer ).
Do you have the H/K system ( States Harman / Kardon on the silver-ish speaker grille ) ?
If so:
Harman Kardon Loudspeaker For HK Systems - Front - Priced Each Part # 65139143273
http://www.ecstuning.com/Search/SiteSearch/65139143273/
If the stock system:
Loudspeaker For Stock Systems - Front - Priced Each Part # 65139143271
http://www.ecstuning.com/Search/SiteSearch/65139143271/
Old Jun 20, 2014 | 11:51 AM
rckrzy1's Avatar
rckrzy1
nobody in their right mind would replace the stock paper junk speakers with another.
Old Jun 20, 2014 | 09:55 PM
joylove's Avatar
joylove
especially without reading all the dead HK amp threads first and then measuring the suspect driver with a multimeter.
Old Jun 21, 2014 | 10:58 AM
Sirjojo's Avatar
Sirjojo
I do have the HK speakers.
Old Jun 21, 2014 | 01:00 PM
rkw's Avatar
rkw
You'll have to determine whether the issue is with the speaker or HK amp (which is prone to failure). Check with a meter as suggested by joylove, or swap the left and right side speakers (if the problem switches side, it is the speaker).
Old Jun 21, 2014 | 02:26 PM
ZippyNH's Avatar
ZippyNH
As suggested...you could swap speakers...give you a chance to look at the wiring...see if the issue follows the part moved...
If it does...buy a new PAIR of speakers.....if the problem stays in the same spot...the you need to look at the wiring, or even the head unit (radio)....
HK systems have lots of amp issues....it becomes a $$$ fix or a complete rewire for a aftermarket radio....
Aug 12, 2015 01:24 PM
Lee-Oh_825
Aug 11, 2015 10:27 PM
maytulip32
Aug 10, 2015 04:00 PM
OutMotoring
Aug 6, 2015 09:32 AM
