R56 2008 Mini sounds like a diesel..sort of
Old Jun 17, 2014 | 09:57 AM
imncrxtc's Avatar
imncrxtc
Hey guys, my wife's 2008 mini (base) started to sound like a diesel, the mechanic said it was the guide of some sort, and or a pulley giving way. I believe this is common with these cars. Can someone tell me what is involved in getting it fixed? I don't want to get fleeced once they have opened my car up. Any insight would be greatly appreciated.
On another note, my R53 is running great.
Old Jun 17, 2014 | 02:16 PM
Ovrclck's Avatar
Ovrclck
Maybe the timing chain is failing?
Old Jun 17, 2014 | 04:45 PM
imncrxtc's Avatar
imncrxtc
Sounds like its coming from the back of the motor on the passenger side.
Old Jun 17, 2014 | 05:49 PM
Cngizbleevng's Avatar
Cngizbleevng
http://www.realoem.com/bmw/showparts...51&hg=11&fg=25
Old Jun 17, 2014 | 06:05 PM
Systemlord's Avatar
Systemlord
Wow you're describing the same noise I have sometimes (not often though) on passenger side back of engine, mine sounds like a metallic overlapping noise/knock. I had my timing chain replaced not to long ago. I pinpointed it to cylinder #4 intake valve side or back. Perform compression check on the #4 cylinder and it seem fine (at 170 psi) which is great. I'm thinking it could be a lifter tapping.
Old Jun 17, 2014 | 06:31 PM
jcauseyfd's Avatar
jcauseyfd
Description sounds like your timing chain guide is destructing (or has already done so). Not common on the normally aspirated engines, but it does happen.
Old Jun 17, 2014 | 09:17 PM
imncrxtc's Avatar
imncrxtc
Do you guys think i can drive like that for a few more days? I commute over an hour each way a day.
Old Jun 18, 2014 | 02:04 AM
Systemlord's Avatar
Systemlord
Nobody can answer a question like that with 100% certainty, you're taking a chance and you know it.
Old Jun 18, 2014 | 04:23 AM
imncrxtc's Avatar
imncrxtc
yes but its a guide right, the timing chain wont break.
Old Jun 18, 2014 | 04:32 AM
jcauseyfd's Avatar
jcauseyfd
The chain probably won't break, but if this is the problem it will need to be replaced anyway as it has stretched out to be too long.
Probably the bigger risk is that the guide is so deteriorated that the chain will have enough slack to jump off one of the sprockets. When that happens is when you see this problem go from being an expensive annoyance to being a catastrophic engine failure.
Really no way to tell how much risk you are taking by continuing to drive it.
Old Jun 18, 2014 | 06:06 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
Honestly if it was me I wouldn't continue to drive it.. The timing chains are such a horrible weak spot that it could go anytime. Also if you are hearing this rattle/diesel sound you may be pushing it already. The risk is just to high for me. Good luck though.
Old Jun 18, 2014 | 07:31 PM
Ovrclck's Avatar
Ovrclck
I just had my timing chain replaced last week.. Guides were cracked, plastic deposits were cleaned out of the oil pan. Don't chance it, take it in for repair.
http://www.promini.com/technical/tec...gine-noise.php
Sent from my Note 3 using NAMotoring
Old Jun 23, 2014 | 05:43 AM
imncrxtc's Avatar
imncrxtc
What is the code for my engine? Its a 2008 non-s.
Old Jun 23, 2014 | 01:35 PM
Cngizbleevng
N12
Old Jun 26, 2014 | 07:28 AM
imncrxtc's Avatar
imncrxtc
Thanks..
For the DIY'ers, where are you guys buying your timing chain kits for these cars??
Old Jun 26, 2014 | 02:36 PM
Systemlord's Avatar
Systemlord
Thanks..
Look what I got when I typed, "mini cooper s r56 timing chain kit" on Google. Lazy?
Old Jun 27, 2014 | 03:37 AM
imncrxtc's Avatar
imncrxtc
Not as lazy as your response... read my question.
"Where are you guys buying your kits"
Old Jun 27, 2014 | 04:37 AM
jcauseyfd's Avatar
jcauseyfd
2008 non-S is an N12, not N14.
Old Jun 27, 2014 | 07:23 PM
Systemlord's Avatar
Systemlord
Your Mini Cooper (base model) has a 1.6 liter N12 engine, it doesn't matter where we buy our parts as long as it's the correct timing chain kit. I purchased my timing chain kit from Irvine Mini, dealers won't have old stock (outdated parts) like some online places do.
Old Jun 27, 2014 | 08:36 PM
jcauseyfd's Avatar
jcauseyfd
Outside of the dealers, I'd probably check Detroit Tuning, ECS Tuning and maybe Pelican Parts for the kits.
lalroma
20
Apr 2, 2022 06:19 PM
MiniJess
Aug 10, 2015 09:51 PM
Ethan Moore
Aug 6, 2015 05:18 PM
kwijmbo
Aug 5, 2015 09:00 PM
