FS:: 3" Alta Performance Downpipe Back Exhaust
Price: $800
Location (Region): Midwestern
Selling a ALTA 3" 2009+ JCW Downpipe back exhaust. Kit is basically brand new. We had it on for less than 10 miles. It was too loud for me so I had to switch back to the stock JCW exhaust for now. Kit retails for $1000, I've discounted it $200 to move it fast.
http://altaperformance.com/i-1400713...bo-engine.html
I had the kit cut to add in more resonators, since that didn't fix it I had it rewelded by Tom's General Welding in Hudsonville so it is a professional Stainless weld. The pipe still lines up perfectly where it was originally. I am only mentioning this because you will see an additional seam compared to a completely new kit. It has zero impact on the kit.
That being said, I had some additional gaskets made for the front connection to the downpipe because the stock flange from ALTA was terrible. I had it made from some thicker aluminum so that it is easier for the pipe to seal. During the first installation I pulled some of the threads from the first vband, so either use the stock one like I did during the second installation or go buy a new one. I also got larger band clamps for the one compression fitting, which will be included since they are of no use to me now.
