Drivetrain FORGE Re-Circ/Blow Off Valve Install
Has anyone had any luck installing this, I've searched but found minimal info with nothing as far as install tips/write ups etc...
Here is the part from Way's website:
Just wondering if anyone has pointers or helpful info regarding install. Cant find PDF
Thanks...
Thanks...
I completely removed the stock plastic intake tube that connects to the front grill area, no need to remove the first half connected to the airbox. Another helpful thing is to unbolt the reservoir and get yourself a bungee cord with hooks on both ends, take one of the hooks and attach it to the metal latch in the middle of the hood and have the other hook attached to the screw hole where the bolt for the reservoir threads in. You're going to need that reservoir out of your way and the plastic intake tubing!
squawSkiBum
Oct 2, 2015 09:21 AM
