FS:: 17x7 O.Z. Ultraleggera Black/205/45R-17 Bridgestone Blizzak LM-60
Category: Wheels & Tires
Price: $0
Part fits (you may select multiples): R50, R52, R53, R55, R56, R57, R58, R59, R60
Make me an offer... No reasonable offer refused. I'll post some pictures. Located in Reston, VA.
4 17x7 O.Z. Ultraleggera BLK PAINT In Stock $261.00 $1,044.00
4 Required centering ring In Stock N/C N/C
4 433MHz Tire Pressure Sensor In Stock $41.00 $164.00
4 Required Valve In Stock $8.00 $32.00
4 205/45R-17 Bridgestone Blizzak LM-60 RFT Runflat - OE vehicl In Stock $158.00 $632.00
4 Mount and Balance (No Charge) N/C N/C
I'm not sure off hand, will see if it's listed on the wheel when I get home tonight. They seemed to sit slightly wider than the OEM JCW wheels though were pretty close to the same. That's why I bought them, was looking for a second wheel set that was close to stock. They are a LOT lighter than the factory JCW wheels though.
Front and Rear
Offset: 37mm
Backspacing: 5.47"
Bolt Pattern: 4-100
Rec. Tire Size: 205/45-17
Weight: 16.0lbs.
Finish: Black Painted
http://goo.gl/QZl6tz
Offset: 37mm
Backspacing: 5.47"
Bolt Pattern: 4-100
Weight: 16.0lbs.
I honestly have no idea what they are worth or what people are willing to pay for them. If you want them make me and offer and we can work something out. I prefer if someone locally can pick them up. I don't have a great way of shipping them.
gar56
Nov 15, 2016 06:41 AM
StrongIslandMini
Sep 19, 2015 10:58 AM
