WTB:: Right Rear Caliper-I really need the spring
Category: Brakes
Price: $0
Come on guys and gals. I know there is one of these in one of our parts boxes somewhere.
Thanks in advance.
///Rich
Hey Rich, hate to tell ya this but it's likely the caliper itself. I had same issue on daughter-unit's R53 and couldn't get 'er to move freely, new spring or no. New cables and a caliper is your best bet. Do 'em both since running the second cable is easier while you're in there, you're adjusting it anyway, and it's a pretty inexpensive "while you've got it apart" thing. I just used a decent caliper from Rock. You can even run the cables without dropping the exhaust if you're careful wriggling the heat shield out of the way. Bleed the brakes while you're at it, then forget about it (aside from routine brake fluid changes) for another decade or so... good luck!
The mechanism moves so good that when I reflexively pull the brake lever and it sticks I can reach under and rotate the pawl by hand to release it.
But in the end, if a new spring won’t stay there, I will be getting a new caliper. And each spring I flush the fluid as part of my spring routine.
///Rich
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
