torque specs
Old Jun 16, 2004 | 07:11 PM
rcoopers's Avatar
rcoopers
torque specs
all right i am getting ready to replace my front pads and i have all the info i need except the torque specs for the caliper bolts...i have searched the forums but could not find what i wanted any help thanks everyone :smile:
Old Jun 16, 2004 | 07:17 PM
Ryephile's Avatar
Ryephile
Tight, but not cranked. The TIS says 30 Nm for the 7mm allen, use a 3/8" rachet and you'll be good to go. Don't forget the rubber caps over those guide bolts!
Old Jun 16, 2004 | 07:18 PM
paddy's Avatar
paddy
Here are the ones for the rear brakes, sorry don't have the front, but would be willing to bet they are same, if not then very close.
Old Jun 16, 2004 | 07:46 PM
rcoopers's Avatar
rcoopers
:smile: thanks for your help so quick....wow....what a community of mini owners....thanks again.......
Old Jan 7, 2007 | 05:28 PM
95Viper's Avatar
95Viper
I assume the 2AZ above is the caliper carrier bracket right? The bolts on our 06 MCC are larger on the front than the rear. Does the 65nm apply for both?
Old Jan 8, 2007 | 02:17 PM
95Viper's Avatar
95Viper
Help...they don't make a 06 Bentley yet. Who has one on a 02-04? What are the caliper bracket torque specs. My front bolt is larger than the rear. I'm dying to install my newly painted red calipers and EBC rotors.
Old Jan 8, 2007 | 02:21 PM
BWROOFCHEX's Avatar
BWROOFCHEX
Tighten them till they break, then back them off 1/4 turn.
Old Apr 8, 2014 | 02:50 AM
rayray40's Avatar
rayray40
Anybody has torque specs for front and rear caliper bracket mounting bolts on 05 Mini?
Old Apr 8, 2014 | 10:03 AM
ashchuckton's Avatar
ashchuckton
From my Bentley manual.
Carrier brackets...
Front 110NM (81ft-lb)
Rear 65NM (48 ft-ib)
Caliper guide bolts
25-30NM (18-22 ft-lb)
I would use blue 242 loctite on the carrier bolts.
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
Willafb
R55 :: Clubman Talk (2008+)
Nov 6, 2015 08:08 PM
Fordgt4
Oct 10, 2015 10:42 AM
MGBill1186
Oct 2, 2015 06:54 AM
gnhovis
Sep 28, 2015 10:56 AM
