R56 Catch can, stock intake
Old May 22, 2014 | 04:27 AM
wb123mb's Avatar
wb123mb
What's a good mounting spot for a catch can while I have the stock intake in? Any brands I should avoid?
Old May 22, 2014 | 04:35 AM
vetsvette's Avatar
vetsvette
Moderator
Looking from the front of the car. There is a tab on the firewall just to the right of the stock air box. That's where my BSH is mounted and where I've seen most others mounted. I think the tab was originally intended for a hood sensor with the factory alarm system, but I might be mistaken about that.
Old May 22, 2014 | 12:56 PM
SoCal MCS's Avatar
SoCal MCS
I have a BSH OCC....originally I had it on the firewall mounted to the bracket that has the alarm system pickup for the hood...(top right of photo). When I added the NM intake, I moved it to the bracket just above where the stock intake air inlet snorkel lived.
Overall, pretty happy with the product/results and looks.
Old May 22, 2014 | 05:37 PM
wb123mb's Avatar
wb123mb
yeah, you guys have a good idea- i'll go ahead and pull the trigger and get one. I'll probably get some parts together to run a petcock and drain hose for it though, so I don't spill sludge all over my steering.
Thanks for the help, hopefully this'll do wonders for the coking problem
Old May 22, 2014 | 06:10 PM
mbwicz's Avatar
mbwicz
Get a syringe or something to suck out the fluid from the dipstick hole. I have a hand powered vacuum pump with a resevoir. I think that BSH offers a syringe for that purpose. Don't mess with the drain plug....
Have fun,
Mike
Old May 24, 2014 | 08:33 AM
zrickety's Avatar
zrickety
What is your goal with the catch can? My experience on the VW is it's just another thing to do. You will still get buildup on the valves and performance will not really change. Better to set aside some extra gas money and do an 'italian tune up.'
Old May 24, 2014 | 08:50 AM
DTH2CHRM's Avatar
DTH2CHRM
I no longer have the stock intake installed, but i did (as already mentioned) install mine on the tab near the firewall which is used if you have the factory alarm. Made a custom bracket for it (an idea I got from another member on NAM) so it sits lower and clears the intake hose.
Mini7
Feb 2, 2016 07:52 PM
wkp1219
Nov 13, 2015 07:52 AM
David.R53
Sep 1, 2015 06:49 PM
Devoman
R55 :: Clubman Talk (2008+)
Aug 25, 2015 10:59 AM
M7Speed
Aug 6, 2015 01:48 PM
