R60 2011 - N18 Water Pump/Timing Chain? eek2:
Old May 21, 2014 | 02:12 AM
svntsvn's Avatar
svntsvn
Symptoms, rough idle, increased engine noise. squealing when shutting off. No cel light.
*Timing chain tensioner work performed. (2011 model w/ recalled part) No open bulletins. Latest software flash along with clutch replacement. New dme, two wiring harnesses, maf, oxygen sensor, oil pump solenoid,
FIRST VIDEO:
Cold startup, with ac on:
Injector noise, check. Wastegate rattle, check. "thats normal" until 2013.
Light whine (vacuum cleaner sound, ac related? air pump?) at startup? Note: AC is on at startup.
How's everything else seem? It's just all getting louder, within two oil changes. Actually had more, but still sad by any standard.:
SECOND VIDEO:
Engine warmed to operating temp, turned AC off.
WATER PUMP? May be a little squeak during idle, think I've heard it before. Definitely there during shutoff. Seems consistent with other diagnosis for water pump, but just need to verify with others.
INFAMOUS DEATH RATTLE? This thing sounds increasingly terrible.
If you need me to shoot better video, or specific area, no problem I was in a hurry.
Thanks!
Colt45Magnus
Aug 27, 2024 05:03 AM
patsum
26
May 29, 2021 06:29 PM
BRracing
Oct 24, 2015 10:07 PM
one73ronin
23
Sep 22, 2015 09:56 AM
renchjeep
Sep 6, 2015 01:54 PM
