R56 Won't run...
Old May 15, 2014 | 05:10 PM
ubuyifly's Avatar
ubuyifly
Won't run...
My 07 S will start and run for a few seconds and then die. Sounds similar to when the High pressure fuel pump died. Here is the new bit of info for you, I replaced the front/rear brakes, rotors, sensors. I looked at Google to reset the brake indicator and one guy said to hold the two buttons on tach for a long time and then it would go into a light test mode and then I could scroll thru different things to reset. I could never get it to do anything after the light test mode. Now it won't run. Did I put it in to some sleep mode where it won't run??
Help
Oct 1, 2015 12:13 PM
potterstein
Oct 1, 2015 07:10 AM
Sep 30, 2015 11:39 AM
Sep 30, 2015 11:38 AM
Sep 29, 2015 12:11 PM
