R50/53 Help with light that appeared on Navigation Screen
Old May 14, 2014 | 07:15 AM
Crazyhorse's Avatar
Crazyhorse
A yellow light pop up on Navigation screen left top part of screen. I looked in the Nav manual but nothing there on this light. I will try to load a pic.
Attached Thumbnails Help with light that appeared on Navigation Screen-nav-light.jpg
Old May 14, 2014 | 07:29 AM
Saltysalt's Avatar
Saltysalt
thats your brake wear sensor, check your brake pads, the wire got cut
Looks like the brake pad sensor warning light. Which means either the front or rear pad sensor has tripped. Could be low thickness pads or the pad sensor has failed. Check the brakes and the sensor, just to make sure the senor did not fault if the pads are newer.
https://www.northamericanmotoring.co...orum-help.html
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
nismo4life
Aug 5, 2015 08:31 AM
