High Pressure Fuel Pump, MINI wont replace mine!
Old May 13, 2014 | 03:51 PM
Snowman_Mini's Avatar
Snowman_Mini
My wife drives a 2009 Cooper S, with only 45k miles, and it developed a fuel pump problem. I called mini to ask about the extended warranty and to schedule a time to bring it in. They told me since my car is out of warranty, that the extended warranty on the pump doesn't matter.
Has anyone else dealt with mini not covering their extended warranties for this, and how have you dealt with it?
Any help is appreciated.
Old May 13, 2014 | 04:40 PM
DneprDave's Avatar
DneprDave
I think that the extended warranty applies to a replacement High Pressure Fuel Pump, not the original pump. So, if your car has it's original pump, you are out of luck.
Dave
Old May 13, 2014 | 05:07 PM
RobMuntean's Avatar
RobMuntean
It's covered 8 or 10 years I can't remember, or up to 120k miles.
Good luck! They didn't cover mine cause MINI USA said my part isn't in the system like the other MINIs...hahah a bunch of idiots. Glad I got the job done by a good shop in Detroit Tuned.
Old May 13, 2014 | 05:08 PM
Snowman_Mini
Dave
That doesn't make any sense.
Old May 13, 2014 | 05:17 PM
jcauseyfd's Avatar
jcauseyfd
You are talking about the high pressure fuel pump, correct? If so and your MINI was one of those specified, the warranty on that part is 10 years/120,000 miles. I got mine replaced at 117,000 miles, so clearly the regular warranty has no bearing.
Maybe escalate the issue with the dealership. If no luck, contact MINI USA.
Old May 13, 2014 | 05:19 PM
Snowman_Mini
I did call mini USA, after my dealer denied me, and they are the ones who told me they won't cover it.
I feel like I am being seriously dicked around right now.
Old May 13, 2014 | 05:43 PM
DneprDave's Avatar
DneprDave
Sure it does, think about it. If the old design craps out under warranty, they replace it with a new improved pump. That new improved pump would have an extended warranty, not the old pump that was poorly designed.
Usually parts replaced under warranty are guaranteed for an additional two years.
I could be wrong.
Dave
Old May 13, 2014 | 05:44 PM
Snowman_Mini
I could be wrong.
Dave
Right, but if mine was never replaced, then why wouldn't it be covered?
Old May 13, 2014 | 05:51 PM
jcauseyfd's Avatar
jcauseyfd
Any possibility the hpfp was already replaced under warranty and the replacement is now outside of the 2 year replacement part warranty?
Sounds like another call back to MINI USA may be in order.
Old May 14, 2014 | 03:51 AM
JR2012IBB's Avatar
JR2012IBB
Is the OP speaking about the HPFP or the regular pump in the tank? I think the 'regular' pump is not part of the extended warranty but the HPFP is.
Old Jun 11, 2014 | 11:15 AM
bmx045's Avatar
bmx045
the low pressure pump is not warrantied, high pressure is(regardless of your car's warranty status).
dealer has replaced my hpfp twice all for free
Old Jun 13, 2014 | 04:45 PM
Systemlord's Avatar
Systemlord
I could be wrong.
Dave
You are wrong dave, you don't make any sense.
I receive a letter from Mini USA stating that they have extended the warranty on the high pressure fuel pump because of a massive number of HPFP failures (10 years/150k), exception is if you originally had it replaced under warranty mini will not cover it just like they will not cover the timing chain if done under warranty.
Mini will only cover the original high pressure fuel pump and the original timing chain.
Old Dec 15, 2015 | 05:19 PM
kitkat729's Avatar
kitkat729
Waste of time talk to mini
Mini denied 2 times to replace the faulty high pressure pumps. Car had about 80k miles. the warranty covers 120k miles. Mini is fun when it is not broke. However, it breaks 90 percentage time here or there. The cost of ownership will be 100% on top of what you paid. I will never go back to mini again.
Old Dec 22, 2015 | 08:05 AM
nkfry's Avatar
nkfry
What year car did you have? The HPFP warranty only covers 07-09 cars, even though the 10's used the same pump they deny coverage to 2010 owners.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Dec 23, 2015 | 11:25 PM
Peanut61's Avatar
Peanut61
my god, the Mini is a POS
09R56
Nov 16, 2022 10:49 AM
TREX
Nov 2, 2019 07:31 PM
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
