Drivetrain R58 and Forge Diverter Valve
Hello, I have a 2013 JCW r58 and I am trying to figure out the correct install of the forge Diverter hoses. I see some run off of the bost tap at the MAP sensor and some run off a boost tube thats right next to the diverter.
Can anyone clarify what I should be running it. Even forge has me confused.
Yes. Just make sure you are using the right spring. Also, you should have plenty of hose to route it wherever you need. Just a note too, depending on where you drive and the conditions, you may need to disassemble the valve and grease it after a year or two.
patsum
26
May 29, 2021 06:29 PM
