Drivetrain R58 and Forge Diverter Valve
Old May 13, 2014 | 02:07 PM
wheresaldo's Avatar
wheresaldo
Hello, I have a 2013 JCW r58 and I am trying to figure out the correct install of the forge Diverter hoses. I see some run off of the bost tap at the MAP sensor and some run off a boost tube thats right next to the diverter.
Can anyone clarify what I should be running it. Even forge has me confused.
Old May 13, 2014 | 02:10 PM
zcast's Avatar
zcast
I ran mine off a boost tap off the MAP sensor in the back.
Old May 13, 2014 | 02:17 PM
wheresaldo's Avatar
wheresaldo
Excellent thanks! and just to verify.. you have both nipples on your diverter right? Uper and lower. I have seen some with just upper.
Old May 13, 2014 | 02:28 PM
zcast's Avatar
zcast
Yes. Just make sure you are using the right spring. Also, you should have plenty of hose to route it wherever you need. Just a note too, depending on where you drive and the conditions, you may need to disassemble the valve and grease it after a year or two.
patsum
26
May 29, 2021 06:29 PM
Sep 16, 2015 02:10 PM
Sep 16, 2015 02:09 PM
Sep 14, 2015 12:48 PM
Sep 10, 2015 10:52 AM
