R56 Cylinder 4 misfire after spark plug replacement
Old May 11, 2014 | 05:44 PM
highpressuresteam's Avatar
highpressuresteam
How hard can replacing spark plugs be? Did it for 40 years.
Replace the plugs with the proper Beru stock plugs on a standard 2009 Mini Cooper(65k). Plug all light tan.
First of all, which is the number 4 cylinder, driver side for the passenger side? Any ideas why I would get rough running at idle and a check engine light after changing plugs. Cylinder 4 miss fire.
Thanks in advance
Mark
Old May 11, 2014 | 06:29 PM
pokeyjoe's Avatar
pokeyjoe
Veteran: Navy
Driver's side. Did the wire on the coil seat properly?
Old May 11, 2014 | 07:51 PM
highpressuresteam
If you mean the high voltage wire, I'm pretty sure. Will check again. I didn't disconnect the connector from the coil before pulling the high voltage lead off the spark plug.
Old May 12, 2014 | 08:30 AM
afadeev's Avatar
afadeev
Reset the codes, re-seat the coils on the spark plugs and the harness wires on the coils.
Re-test and see if it runs smoothly w/out check engine light.
If light returns, swap coils (#4 is indeed driver side) around and reset the the codes again.
See if the misfire code follows the coil, or stays with the plug.
HTH,
a
Old May 12, 2014 | 11:40 AM
bmx045's Avatar
bmx045
this happens a lot when the coil isn't properly seated, if you're positive its correct move that coil to cyl 3 and see if the misfire follows. i just had cyl 4 coil pack go bad out of the blue on me.
Old May 27, 2014 | 12:41 PM
highpressuresteam
Thanks for all the help.
Was a bad coil. Replaced and all is fine. Man, the car runs so much better. Was changing plugs due to low speed hesitation. All cleared up.
I thought the non-S Mini was a real dog til the plugs were swapped. So much better off the line.
Thanks again
eliseo1981
Jan 28, 2021 02:45 PM
blackie
Jan 18, 2017 09:56 PM
silence2-38554
98
Sep 21, 2016 02:52 PM
maniacalmorgan
Aug 19, 2015 08:44 AM
yashmack
Aug 15, 2015 10:16 AM
