Suspension Ohlins DFV R&T for 2014 JCW Coupe
Old Apr 28, 2014 | 11:06 AM
j997tt's Avatar
j997tt
I was planning to do the JCW suspension on my new Coupe but after researching options I want the Ohlins. Can anyone tell me whether these will fit my car? I have been to ohlins website and they only specify fitment for the R56. Any help would be appreciated. Also plan to do a rear 19mm rear SB. The car will be street driven but also tracked occasionally. Thanks.
Old Apr 29, 2014 | 10:18 AM
whrisk's Avatar
whrisk
i am pretty sure if your chassis code is an R56 it will fit. if i am not mistaken the JCW suspensions fit on the R56S.
Also you should probably go with the Hotchkis 25.5mm sway bar. it has almost been unanimously decided that its the best sway for the R56 from all the stuff that i have read.
Old Apr 29, 2014 | 11:04 AM
ra2fanatic's Avatar
ra2fanatic
You'll love the Ohlins and the 25mm Hotchkis bar is great, but the holy grail goes to Tarett.
Old Apr 29, 2014 | 11:44 AM
whrisk's Avatar
whrisk
edit
Old Apr 29, 2014 | 11:50 AM
ra2fanatic's Avatar
ra2fanatic
Look again and you'll see that they do offer a swaybar for the MINI.
Old Apr 29, 2014 | 11:52 AM
whrisk's Avatar
whrisk
yeah i found that.
Old May 10, 2014 | 12:09 PM
Systemlord's Avatar
Systemlord
Are the pictures of you StopTech Trophy BBK? Anyhow I see some serious grooves in those rotors.
Old May 10, 2014 | 01:36 PM
ra2fanatic's Avatar
ra2fanatic
The rears are Centric Slotted Rotors. And the fronts are slotted Aero Rotors.
SosoMINI
Nov 22, 2015 03:17 PM
FrostyFox
Oct 28, 2015 02:06 PM
JPMM
Aug 13, 2015 12:01 PM
Terry J
Aug 11, 2015 09:39 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
