R60 Sirius xm code?
Sirius xm code?
I just picked up my countryman 2 days ago and I'm absolutely loving it. The one option I'm (only semi) regretting is not getting sirius satellite radio. Has anyone activated sirius after-market? I have mini connected w/nav, and from everything I'm reading, it looks like that means I have the hardware there- I just need the code to activate it. Should I do this through the dealer, or is there a 3rd party method that would be better (and cheaper)? Thanks!
Hi
Here is what I did.
The dealer purchases an activation code.
They then download the new firmware code from a Server, then apply it to the Mini.
The process took a day, but thinking an hour or so for the technician.
I asked if I could do it myself, but it needed their infrastructure to do so.
It will cost you about $400-500 for the upgrade and install.
Once I picked up my Mini contacted sirius and paid $100 for a year of service.
The 1 free year expired back in Jan 2014
It is a bit pricey, but do enjoy it for my commute to work.
The hardware is already there, it is a new firmware code that unlocks it.
I am not sure if this can even be done 3rd party, but worth a try to see if you can find someone that can for less money.
Here is what I did.
Thanks gregus73 that helps a lot. I should have just added it when I ordered the car, but there's no sense in regretting that now. I'll speak with my dealer and see what he says about how long it would take/how much it would cost.
As far as 3rd party, I heard of a website called bimmertech that sells the code/1 year subscription for $275 and they guide you through the process of installing it. I contacted them to make sure it's compatible with my car and I'm waiting for a response. If that'll work- then I'll probably just go that route and save the couple hundred bucks.
Thanks for the info!
I installed my Stratus 5 into the base radio rather purchasing the H-K, Factory Sirius, or Factory Nav.
My Stratus 5 is a lifetime that I purchased back in the day (2008). No monthly fees!
I use 2 black soft hercules cupholder mounts - left for sirius, right for iphone 5 navigation when needed. I just got a cool black retractible iphone lightning cable usb charger that tucks away nicely when not needed too.
I tried to fish out the factory antenna but no dice. I cleanly installed the Sirius Stratus antenna and it discreetly fits on the right interior corner dashboard with excellent reception.
Really happy as everything is on the down-low yet easy to see and reach. I set the AUX volume on both the Stratus and the MINI to maximum. I also set MINI treble to max, and MINI acceleration compensation volume to max with all other settings to default which is perfect for my middle aged ears.
Thank God for SiriusXM channel 53, Chill, where it plays most of the time.
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
GregoryK
Dec 14, 2015 01:34 PM
ShadyCoop
Sep 20, 2015 08:57 AM
