R50/53 Compression Check // Need Help
Old Apr 21, 2014 | 01:56 PM
minibuddy's Avatar
minibuddy
Hello All,
revised (04/21/14 10:21 pm) got a new test guage
2003 Cooper (non-S)
Engine Cold
Here are my readings:
Cyl # / Dry Reading / Wet Reading
# 1 / 160 / 210
# 2 / 190 / 240
# 3 / 180 / 230
# 4 / 205 / 255
Can anyone tell me what they might think is going on?
With exception to #1, the numbers look good to me?
Blown head gasket, bad valve, busted piston rings?
I have not done a leak down test at this point.
Comment:
When doing a compression test, crank the engine the same number of times on each test. The Bently books says 4 to 6 TDC strokes. I choose 6 strokes per cylinder. ( I did not do that on my initial test and the readings were all over the range.
Just for kicks, I decided to get the max psi / number of strokes.
Here is the date
#1) 205 psi in 15 strokes
#2) 225 psi in 15 strokes
#3) 210 psi in 15 strokes
#4) 235 psi in 15 strokes
At least is was consistant in the number of strokes to max psi.
Tell me what you think.
Last edited by minibuddy; Apr 21, 2014 at 08:25 PM. Reason: Purchased new test guage.
Old Apr 21, 2014 | 03:46 PM
ZippyNH's Avatar
ZippyNH
What is the car doing that lead you to do a compression test?
What are the numbers? Not psi....knda helps to know to make it easier to compare vs other known cars with numbers....
Old Apr 21, 2014 | 03:55 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
I think you better recheck your readings..
minibuddy's Avatar
minibuddy
2003 Cooper (non-S)
Engine Cold
# 1 / 210 / 290
# 2 / 235 / 275
# 3 / 206 / 265
# 4 / 256 / 300
These numbers are all over the board.
Here are the Bently Service Manual technician readings :
Compression Specifications
Compression range
Cooper (non-S) : 167 to 247 psi
Cooper S : 131 to 196 psi Max difference between cylinders : 7 psi
Old Apr 22, 2014 | 07:29 PM
GreekDrifter91's Avatar
GreekDrifter91
From all my knowledge to get accurate readings you need to do the compression test with a HOT engine. with a cold engine you will get blow by.... try that first, get the engine up to operating temp. turn it off get the plugs out, disconnect coil pack, pull the fuse for the injectors and crank away.
Old Apr 22, 2014 | 10:42 PM
BlwnAway's Avatar
BlwnAway
Also, consider getting a second gauge, cheepo, loaner, anything, just to get another reading for comparison and gauge checking purposes.
Old Apr 23, 2014 | 02:00 AM
ZippyNH's Avatar
ZippyNH
What performance issue are you having....
Numbers seem to be pretty typical of a "runner".... Sure nothing perfect...but wear happens....
Manual numbers fora car/motor are not EXACT.....simple fact is...if it runs well...drive. It is not like a computer with precise readings.... Guages are imprecise....valve seating and even rings tighten and loosen with temp and postion....
So again...what performance issue lead you to do a compression check other than you just want to know....
jwillis
Sep 2, 2015 02:19 PM
Sep 2, 2015 09:05 AM
SneedSpeed
Sep 2, 2015 05:34 AM
kpl
Aug 11, 2015 04:52 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
