Suspension Koni yellow incompatibility issue
Old Apr 20, 2014 | 08:17 AM
Minidaho's Avatar
Minidaho
While having some H&R springs and Koni yellows installed yesterday, we ran into an incompatibility problem with the top of the rear struts and the stock "top hat" for the strut. As confirmed by Cy at Tire Rack, the opening in the hat is 10mm, while the strut bolt is 12mm. I can't believe I'm the first one to have this problem. We ended up having to drill out the hole to make the strut fit. Wondering whether Koni will include an aftermarket strut hat with future strut sales or at least let buyers know that they will have to do some drilling.
Old Apr 20, 2014 | 11:41 PM
Wrecks's Avatar
Wrecks
Yeh I had to drill it out too. But I knew this way in advance reading this forum. I agree at least print it in the instructions to drill it out. Aftermarket top hat would be overkill.
Old Apr 21, 2014 | 06:04 AM
cristo's Avatar
cristo
Alliance Member
This has been well noted on this and other forums for years, but it would be proper for
Koni themselves to include it in product descriptions, installation instructions, etc.,
wouldn't it??
Old Apr 21, 2014 | 06:46 AM
whrisk's Avatar
whrisk
i would not call that an "incompatibility issue". a lot of cars you cannot even get bolt in koni shocks. they only offer inserts. which means you have to cut the old shock body off the shock and reuse the lower perch of the shock and bolt the koni into it.
So i think enlarging a whole by 2 mm is not really an issue.
Old Apr 21, 2014 | 07:44 AM
Minidaho's Avatar
Minidaho
OK, I must have missed any post where it said that drilling was required. I ran a ton of searches on Koni shock upgrades and other suspension/coil posts and never saw this. Newbie mistake. My bad. Won't happen again.
No, drilling was not a problem - just an unexpected step. Struts and H&R coils work great.
minimofo
Nov 16, 2016 05:56 AM
sdotbailey
R55 :: Clubman Talk (2008+)
Sep 16, 2015 09:03 AM
blackie
Aug 25, 2015 09:08 PM
Emnotek
Aug 13, 2015 05:47 PM
mini yellow-haa!
Aug 13, 2015 11:18 AM
