p0442 Check Engine Light
Old Apr 15, 2014 | 09:37 PM
penumbra547's Avatar
penumbra547
Hi All,
long time lurker, first time poster. I have a 2012 Mini Cooper Coupe, Base, and went in for my 16K mi service this past weekend. Got the car serviced and was told something was leaking and the oil leak was getting into the computer. Not sure, but was told it's a know problem and got it fixed under warranty.
That said, got my car back and within 5 miles of the dealership, the car throws a check engine light. Pull the code, and it was a P0442, supposedly a minor leak in the fuel system. Got back into the dealership and they apparently fixed it by reprogramming the ECU? based on what I found, most people do the smoke test to see where the leak occurs and fix it that way.
My question is, when they reprogram the car, are they just masking the problem by somehow decreasing the sensitivity of the sensors, or is reprogramming the car truly a fix?
thanks in advance!
Old Apr 16, 2014 | 11:24 AM
Slave to Felines's Avatar
Slave to Felines
Your leak was almost certainly the oil pump solenoid. I had the same thing in my '12; they replaced the solenoid plus the wiring harness it leaked into. That new harness has a different connector at the thermostat housing, so they replaced the housing as well with the updated version.
A leak in the fuel system would be a leak of gasoline. You'd probably smell it if it were really leaking. You can't smoke test the fuel system--that's done for leaks in the intake.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
