Cam Tensioner Bolt Seal.
Old Apr 15, 2014 | 11:21 AM
Yakatak's Avatar
Yakatak
Wife just returned from routine maintenance visit with dealer. They noted small oil leaks at the valve cover and the cam chain tensioner bolt. No problem replacing the valve cover but i can't seem to find any info on replacing the seal (crush washer?) for the tensioner bolt. Can anyone point me to a thread with some info on the process or a part number for the seal?
Jon in SC
Old Apr 18, 2014 | 06:51 AM
Everyday I'm Motorin's Avatar
This should be what you're looking for. Item 5.
http://www.realoem.com/bmw/showparts...24&hg=11&fg=25
Old Apr 18, 2014 | 07:46 AM
Yakatak's Avatar
Yakatak
Thanks. I did find that...still looking for a "How to".
Great Sig. If only my wife didn't love this car so much. Sigh.
Old Apr 18, 2014 | 08:04 AM
This is the only video I know of that shows what you're looking for. I had a Bentley manual when I had my mini and it was very helpful. I don't know of any written instruction other than what's in the Bentley manual. If the video doesn't help, just keep search but it should point you in the right direction.
Old Apr 18, 2014 | 08:13 AM
wb123mb's Avatar
wb123mb
Is it the actual tensioner (part 4 and 5) or is it the screw that holds the plastic guides in place?
If its the tensioner (4/5) I just replaced the whole tensioner, it has an aluminium washer (pelican part 11-31-7-631-972-M131 for an r56, N14) and its tensioned to something like 65Nm, w a 27mm socket. It's pretty easy to get to, on the back of the motor, pull off the airbox (MCS) and undo the hose clamps to remove the plastic wye charge air tube stuff, and it's right there. Be careful of the sensor that's right beside it.
if its the one that holds the plastic guides in place, i think its an allen key'd bolt that has a rubber o-ring to keep it from dripping. It'll be on the right (passenger) side of the motor, and I haven't messed with it, but imagine you can access it best by pulling the fender well. if its towards the front of the car it should be 11-31-7-534-771-M26 (gasket 11-31-7-534-770-M26) if its to the rear 11-31-7-534-768-M26 (o-ring 11-31-7-550-461-M131).
believe it or not, i don't work for pelican. i just shop there a bunch.
Old Apr 18, 2014 | 08:29 AM
Yakatak's Avatar
Yakatak
Thanks Guys! I have the Bentley, so I'm good to go.
Jon in SC
patsum
26
May 29, 2021 06:29 PM
JaysinStrife
Jun 3, 2016 09:19 AM
weaver9000
Sep 14, 2015 05:48 PM
Sep 10, 2015 10:52 AM
Sep 8, 2015 11:37 AM
