R56 Fault code P00BD any ideas?
Old Apr 13, 2014 | 10:14 PM
Wing it's Avatar
Wing it
I first had a code for cylinder misfire replaced all my plugs car is not sputtering when I floor it anymore but now I'm getting this fault P00BD is my mass air flow sensor bad?
Mass or Volume Air Flow "A" Circuit Range/Performance - Air Flow Too High
Old Apr 19, 2014 | 03:19 AM
Wing it's Avatar
Wing it
Figured it out!
Figured it out thanks for nothing!
Old Jun 28, 2014 | 08:49 PM
CaitOh's Avatar
CaitOh
Bump
I'm having the same issue. Just had entirely new wiring harness and ECU installed due to a oil leak at the solenoid.
Car drove fine for first two days after getting it back, but now seeing a CEL and when I scan the code I get the same P00BD code you mentioned, indicating air mass sensor is reading high volumes of air.
What was your solution? Anyone else have any ideas? Tried an ECU reset and also tried clearing the code with the scanner, but to no avail.
Any help would be much appreciated. Hoping I'm not running lean and about to blow my motor...
Old Jun 28, 2014 | 09:08 PM
Wing it's Avatar
Wing it
P00bd
My original problem was a misfire replaced my plugs then had the poobd code I first cleaned the maf but that didn't work but what my problem was a hose wasn't fully seated near the passenger side coming off the air filter box. I secured the hose and it's running great.
Old Jun 28, 2014 | 09:14 PM
CaitOh's Avatar
CaitOh
Originally Posted by Wing it
... but what my problem was a hose wasn't fully seated near the passenger side coming off the air filter box. I secured the hose and it's running great.
Hey man, thanks! I'll have to check it out! Hoping it's that simple... :D
Old Jun 28, 2014 | 10:49 PM
CaitOh's Avatar
CaitOh
LIFESAVER! Wouldn't you know, the intake boot wasn't attached properly. Thank you, thank you. You saved me a boat load of time, stress and money by letting me know. Reattached boot, reset ECU and I'm CLEAR! Thank you, wing it. I mean it.
danielbrookes_9
Oct 3, 2015 12:51 PM
Chasp
Sep 4, 2015 09:31 AM
bcman
Aug 28, 2015 04:47 PM
scottrn
Aug 22, 2015 07:26 PM
quality_sound
Aug 7, 2015 09:36 AM
